USB to I2S 384Khz - DSD Converter - Page 165 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 25th July 2013, 10:00 PM   #1641
If you mean if it can run natively on 45/49 XOs then I believe the answer is no. IIRC Domenico told me once max internal clock speeds are 22/24.
You can run it in sync with external 45/49 or 90/98 XOs but they'll need to be divided accordingly.
Old 25th July 2013, 10:05 PM   #1642
RollE2k is offline RollE2k  Sweden
Ok, too bad, i thought it would be possible to run natively - but anyway, this is better than nothing. Thanks for the fast answer!
Old 26th July 2013, 05:52 AM   #1643
aren't the different firmware files available for download for archival purposes?
I mean for playing with different versions without using the internet connection to be connected to the amanero servers all the time?
and also for the purpose if one likes an older vers of the firmware and suddenly Domenico decides not to host it anymore on it's servers...
== There are no limitations to the self except those you believe in ==
Old 26th July 2013, 07:17 AM   #1644
What kind of advantage where you expecting from having it running from higher speed XOs?
The better, faster XOs belong in the DAC itself as close as possible to the chip. Ruuning them on the Combo with theh added jitter from its ICs wouldn't make that much sense IMO.
Old 26th July 2013, 07:22 AM   #1645
I'm afraid it is not and will not be possible. I assume it is a basic protection against decompilation and code copying.
In the tool there are always at least two firmwares available, the previous 100% stable and the lastest released. It is always possible to revert to previous stable in case of any problem. Going further back is pointless as all functionality is included in the previous stable and all known bugs known at its release time are fixed.
Old 26th July 2013, 07:36 AM   #1646
acko is offline acko  Australia
Couldn't agree more! DAC and transport have different timing requirements and the prescaling to match ESS DACs is the best approach while maintaining compatibility with other DACs. Also, internally the CPLD is running on the know good timing of it native 22/24 mode so if there are any sonic issues with this upgrade then it is clearly external to the transport.
AckoDAC Project
Old 26th July 2013, 11:32 AM   #1647
mksung is offline mksung  Taiwan
Hi, Domenico, Have any plan to support hardware volume control?
In the Linux, can see the ctl dev, but is is malfunction.
[root@localhost ~]# amixer
Simple mixer control 'Combo384 Amanero',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Limits: Playback 0 - 32767
Mono:
Front Left: Playback 32767 [100%] [0.00dB] [on]
Front Right: Playback 32767 [100%] [0.00dB] [off]
Simple mixer control 'Combo384 Amanero',1
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Mono: Playback 32767 [100%] [0.00dB] [off]
Old 26th July 2013, 10:08 PM   #1648
deanoUK is offline deanoUK  United Kingdom
Using a Si570 clock board from Ian and manually selecting the frequency -
22/24 Amanero divider set to /1 - OK
45/49 Amanero divider set to /2 - OK
90/98 Amanero divider set to /4 - Not working
Anyone else tried 90/98 ?
Old 28th July 2013, 12:56 PM   #1649
@Jackal29a please tell me when updating the new firmware after resetting the device, I have 3 options in the first CPLD flash menu that are - master2224, slave2224 and CPLD_for_1079 ;
now, I see that the first option "master2224" is the defaul one, but when I select the third option "CPLD_for_1079" then it is stated in the info box that "Flash this version associated with CPU firmware 1.079"
so my question is, if I want to upgrade to the new 1.079 firmware (flashing CPU as a second step with this new firmware), do I have to select this third option in the "FLASH CPLD" menu?
Old 28th July 2013, 03:00 PM   #1650
Correct. Flash both CPLD and CPU with 1.079.
Enviado desde mi GT-I9100 usando Tapatalk 2
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
