USB to I2S 384Khz - DSD Converter - Page 162 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 6th July 2013, 10:31 AM   #1611
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by vuki View Post
Hi DQ828,
I'm using it this way without any problem.
Thank you
Old 9th July 2013, 11:56 AM   #1612
clsidxxl's Avatar
I want to feed the card with a Audio gd psu l, I have to connect like this
Originally Posted by DQ828 View Post
I was planning on bringing a permanent 5v power supply to the Amanero as per the image below, basically solder it on to either side of C27 & cut the trace leading to the USB power in.
Can anyone see any issues with doing it this way?
or solder directly behind the USB connector?,
to connect the grd to the psu I take the usb output pc?
untitleda978421837d6514ca196e356fae40448 shared on ZimageZ
Old 9th July 2013, 05:00 PM   #1613
Is the PC able to detect the amanero since it is not drawing supply from the PC USB?
Old 9th July 2013, 09:17 PM   #1614
vuki is offline vuki  Croatia
vuki's Avatar
PC detects the amanero.
Old 10th July 2013, 06:01 PM   #1615
clsidxxl's Avatar
Originally Posted by s3tup View Post
The origin is not having ground reference.
Please a little help
Can I use the usb grd side PC?
Old 10th July 2013, 09:59 PM   #1616
Default Firmware Update Tool
Domeinco has released a new 1.14 version of the update tool avilable at this link:
http://www.amanero.com/oemtool114.zip
It introduces two changes:
1) Combo384 model selection: When starting the tool a window will pop-up asking for OEMID, for standard Combo384 models purchased from Amanero just leave the default "combo384" (do not use caps). The "Advanced" tab will be disabled for regular Combo384s.
2) Redesigned "Firmware Prorgamming" tab, now each possible action (CPU flash and CPLD flash) has its own informative panel:
If a new firmware requires not only the standard CPU flash but also a CPLD flash it will be stated in the information panel.
More news, firmware 1.076 is avaliable with a fix for reducing clicks and pops when changing from PCM->DSD and the other way around.
Process for changing to salve mode firmware:
1 ) select slave2224
2) Press FLASH CPU
3) when done unplug - replug and wait 4 seconds
4) unplug - replug
5) select firmware 1.074
6) press FLASH CPU
Old 10th July 2013, 10:01 PM   #1617
Can you say Audio?
Just to confirm: steps#2 & #6 are 'FLASH CPU'. In my past experience attempting this, the second flash fails with the message that you need to reset (erase) the device. Should the first flash be 'FLASH CPLD'?
Old 10th July 2013, 10:03 PM   #1618
I thought it sounded weird too and asked Domenico twice but got the same answer each time. Haven't tried it myself yet.
Old 10th July 2013, 10:05 PM   #1619
Can you say Audio?
Hmm. Ok, I'll try it again this evening. Domenico - given the finicky nature of this, a short video of the process would maybe help. If I can get it to work, I'll put one together.
Old 11th July 2013, 01:19 AM   #1620
Can you say Audio?
Well, I think the above steps will be correct if you change #2 to read 'FLASH CPLD'. Two 'FLASH CPU' calls will have the second one requesting another erase/reset. I replaced it with a 'FLASH CPLD', and believe I've successfully flashed it with the slave2224 CPLD, and the 1.074 firmware.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
