USB to I2S 384Khz - DSD Converter - Page 152 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 14th May 2013, 07:43 PM   #1511
clsidxxl's Avatar
Hello,This interface can be used with a dac Audio GD Ref 7.1 ( PCM1704UK Chips)
thanks.
Old 15th May 2013, 07:27 PM   #1512
clsidxxl's Avatar
What is the connection between Texas I. 1794 uk chips and Amanero board
1794 partagé sur ZimageZ
Old 17th May 2013, 06:20 PM   #1513
Hi - might this be the answer you are looking for?:
I use a DSD1794A and it works fine except that I have ticks each time I choose a new track (with Foobar).
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 18th May 2013, 11:48 AM   #1514
Invoice received and paid.
Any idea when I can expect your parcel?
Zjaakco
Old 18th May 2013, 12:16 PM   #1515
amanero is offline amanero  Italy
Please check your mailbox
Old 18th May 2013, 01:47 PM   #1516
Amanero, it's clear. thank you.
Zjaakco
Old 18th May 2013, 02:28 PM   #1517
Hello Jesper, online there is a firmware version called test_fix_click_foobar.
May you check if this firmware fixes your problem with foobar?
Thank you,
Domenico
Jesper
Old 18th May 2013, 03:06 PM   #1518
clsidxxl's Avatar
Thanks gentlevoice ,the i2s output 32 bit is not problematic with the 1794 uk ,I want to use an external power supply for USB, or connect on the card amanero.
Old 18th May 2013, 05:45 PM   #1519
Thank you,
Domenico
Hi Domenico,
Thanks for replying & ... Yes I'd be pleased to check it out but might you have a link to this firmware version? I don't seem to find it using Google nor on your website ...
BTW will this firmware also play DSD256 & 512 or do you have a link for that as well?
Greetings,
Jesper
Old 20th May 2013, 09:40 AM   #1520
Hi Domenico,
Greetings,
Jesper
Jesper, the Combo384 firmwares are only availble through the flash update tool, you can download it from the following link (make sure you also download and read the manual):
Index of /asiohwd
Run the tool and check the drop down list at the bottom to see all available firmwares.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
