USB to I2S 384Khz - DSD Converter - Page 144 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th April 2013, 06:58 AM   #1431
Added 1 for group buy
Old 8th April 2013, 03:30 AM   #1432
millon is offline millon  Singapore
Please add 1 for group buy
Old 8th April 2013, 11:17 AM   #1433
rtd is offline rtd  France
Added myself in group by
Old 8th April 2013, 04:38 PM   #1434
qusp is offline qusp  Australia
qusp's Avatar
has anyone successfully run the firmware updater tool in WINE on macOS? it opens fine and appears to function fine (without the combo384 plugged in as yet) last update hochopeper helped me out doing it on his windows machine, but that was ages ago and it would be cool to be able to do it here. anything I should look out for?
Old 8th April 2013, 06:06 PM   #1435
Bidule is offline Bidule  France
+1, on the list, do I have to send a separate PM ?
By the for those interrested, I have a Raspberry Pi running Squeezelite Headless;, I'll report if it is working as soon as i get the board and the time to setup with a DAC (TDA 1543)
I have tried recently the Naim Dac-V1 on the Rasberry Pi (it uses Audiophilleo usb-spdif or i2s oem) and it worked like a charm but I only tested 16/44k1Hz materials.
Old 8th April 2013, 10:53 PM   #1436
RollE2k is offline RollE2k  Sweden
I cannot get the firmware update to work, don't know why - the drivers does install when i run the setup, but when looking at my device manager there is a "unknown device" that goes away when unplugging the amanero.. So it's like the driver doesn't lock to the device or something.
And when trying to flash it just tells me i need to erase the device. Erasing does nothing either it seems..
Any idea?
Old 8th April 2013, 11:38 PM   #1437
glt is offline glt  United States
After you erase the firmware, the OS sees an "unknown device". You need to download the ATMEL driver.
I've updated this post with some tips on updating the firmware: Amanero PCM and DSD (Update) | H i F i D U I N O
www.hifiduino.wordpress.com
Old 9th April 2013, 08:44 PM   #1438
Thanks, that will probably solve it then :-)
Old 11th April 2013, 08:15 AM   #1439
patnsh is offline patnsh  Hong Kong
Please add 1 for group buy. Thanks!
Old 11th April 2013, 11:36 AM   #1440
DQ828 is offline DQ828  Australia
DQ828's Avatar
Please add 1 to Group Buy thanks
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
