USB to I2S 384Khz - DSD Converter - Page 14 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 31st August 2012, 06:30 PM   #131
bcmbob is offline bcmbob  United States
MrSlim,
I have Linux on a couple boxes in an old render farm project but haven't touched them in ages. Don't know if I'll ever be a full convert but am willing and able to use Linux if needed.
I'm in the process of working out the kinks in a really bad (bad meaning vendor supplied some real garbage components) second DAC that should qualify. I ordered this TE7022L module that hopefully will show up in the next few days. Many Dac 5 users are already attempting direct I2S integration. I've been informed that this new Amanero card can also be used with the Mini2496.
It will be fun to dig in
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 31st August 2012, 07:24 PM   #132
BTW: Is there a go to third party music player for Linux or is the embedded software sufficient?
Bob M.
Old 31st August 2012, 08:47 PM   #133
amanero is offline amanero  Italy
Hi, thanks for the GB.
This morning i talked with korben69 that invited me to write here how to proceed.
i propose to do in this manner. Monday i'll upload on the site a spreadsheet with the GB nicknames + prices ( 39+shipping+[VAT]+paypalfee ) then you can send me a private message with your email and i'll reply with a paypal payment request.
Thanks again,
Domenico.
Old 31st August 2012, 08:52 PM   #134
Zoran is offline Zoran  Serbia
OK
Old 31st August 2012, 09:25 PM   #135
I did a quick reconfiguration (compiled a new kernel) with NRPACKS=1 and changed the ALSA configuration back to standard and then forces the the interrupt rate / CPU usage up..
This changes the differences and now the OEM Combo384 Module are less than 2 times better than the standard USB 2.0 adapters.
The OEM Combo384 Module responds very good to tweaking and it will be interesting to see what performance it is possible to get.
The initial more than 10x can possibly be tweaked to closer to 20x lower interrupt rate with the identical settings (I would be surprised if the setup I have used was the most optimal..)
Code:
cat /proc/interrupts
           CPU0
  0:      24623  orion_irq  orion_tick
  7:        380  orion_irq  serial
 11:        314  orion_irq  mv64xxx_i2c
 21:      49254  orion_irq  kirkwood-i2s
 24:    2116671  orion_irq  ehci_hcd:usb1
 25:    1222102  orion_irq  ehci_hcd:usb2
 29:      10086  orion_irq  eth0
Old 31st August 2012, 09:28 PM   #136
MrSlim is offline MrSlim  Canada
A lot of the Linux people are using MPD (Music Player Daemon), which uses a Client/Server approach, so that you can run the MPD client on a small, low power (read Silent) device, connected to your DAC, and then have your Music on another machine somewhere (even via ethernet) else. But you can have the Client running on the machine where you store your Music as well. There are a few small/light linux distros (voyage linux for CLI fans, and MPDPup for Noobs..) that already have MPD configured..
A few people have mentioned DeadBeef as being a nice player, and I've dabbled with Clementine, and it seems pretty nice, although I havent done any head to head SQ tests..
Old 31st August 2012, 10:42 PM   #137
Originally Posted by HpW View Post
Does your driver supports ASIO??
Hp
Exactly. No ASIO no DSD playback ...
Old 1st September 2012, 07:38 AM   #138
HpW is offline HpW  Switzerland
Well, is this planned ??? otherwise I consider to skip my order...
While rigisystems.net provides multichannel & DSD & ASIO!
Cheers
Hp
Download FFT Analyzer & Generator at www.hpw-works.com
Old 1st September 2012, 08:32 AM   #139
DoP should work just fine over WASAPI
Could anyone plase explain this line:
"Note
DSD output enable line to signal an incoming DSD stream.The card supports output mode only."
Old 1st September 2012, 08:37 AM   #140
nik_d is offline nik_d  Serbia
nik_d's Avatar
Cheers
Hp
@HpW
You can freely skip this order. You are advertising product costing almost 10 times more. Plus, messrs Rigisystems refused to sell their product to me, almost a year ago. They even asked me to sign NDA, which I did, and still did not invoiced me nor sent their toy. Lot of international calls for nothing. I survived without them, thanks. Amanero is offering simple an I hope effective device for all my needs.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
