USB to I2S 384Khz - DSD Converter - Page 139 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 24th March 2013, 04:33 PM   #1381
hirez69 is offline hirez69  Europe
Hi Domenico,
is there any news about cpld firmware?
Originally Posted by amanero View Post
it works with 45.xx and 49.xx too.
I need to add a cpld firmware selection in the maintenance tool, in this way you can choose,
cpld master, cpld slave 22/24, cpld slave 45/49
Old 26th March 2013, 01:37 AM   #1382
Send a message via Yahoo to kannan_s
Originally Posted by glt View Post
Thanks Glt
it worked
Amanero
- Yes I received the Cards today
kannan
Old 26th March 2013, 09:57 AM   #1383
Originally Posted by ghiglie View Post
Ciao misterGI,
as far as I can see here: https://docs.google.com/spreadsheet/...wYS1EcXc#gid=0
... I can see the GB5 is still opened. I'm thinking about gettin in this too, maybe we can combine the order.
thank you Ghiglie but at the end I adopted another solution
Old 27th March 2013, 09:50 AM   #1384
Boards arrived, thanks! Going to test soon using I2S(DSD) by TP Opus and ESS9022. J.
Old 27th March 2013, 01:12 PM   #1385
The two boards arrived 5 days ago in Taiwan ~ Thank you Domenico!
Old 27th March 2013, 04:14 PM   #1386
Default Help with I2C
I'm trying to test sending I2C commands from the Combo to a Buffalo II DAC but can't get it to work.
I'd like to ask for help any one who has made any ES901x DAC work with the update tool.
I'm using v. 111a of the Update Tools and 1072 firmware (both CPU and CPLD). Tried with and without Buffalo's on board BIOS.
I've connected pin 2 of the Combo384 to SCL and pin 12 to SDA on the DAC.
As per Domenico's instructions on post #1062 on this thread (USB to I2S 384Khz - DSD Converter)
I assigned the next for simple testing:
On88Set:
address = 0x49
register = 0xA
value = OxCF (mute)
and in case it worked I assigned the following to unmute:
On176Set:
address = 0x49
register = 0xA
value = OxCE (unmute)
Save by clicking "Write Flash"
I also tried changing address to 0x90 but same result. Playing a 88.2K file does nothing, there is music coming through so "mute" command wasn't triggered by 88k sample rate as expected.
Any ideas? am I doing something wrong?
Old 27th March 2013, 04:29 PM   #1387
Javier....the address should be 0x48
Old 27th March 2013, 05:53 PM   #1388
Thx mate
Should it work with the BIOS in place? I just tested with 0x48 and BIOS in place and no effect, still getting music when playing 88.2k
Old 27th March 2013, 07:43 PM   #1389
Sorry not sure which Bios you are referring to here. The one in your PC? If so, probably not relevant here.
There is also normally a earth/ground connection that should go between the Combo and the Buffalo I2C connection. At least there is one in my Buffalo24. Just checked your register numbers and values against the ES9018 datasheet and they appear to be correct to mute and unmute the DAC. I take it, you have tested with a meter to make sure that the I2C wires interconnect correctly?
Old 27th March 2013, 10:55 PM   #1390
Sorry, by BIOS I menat the TPA firmware chip.
Haven't measured yet but I'll try doing SCL tomorrow, guess it'll be TTL 1.65V level, right? measuring data could be problematic if it produces short burts when commands are sent.
I'll also try post some pics of the wiring but I did twist each wire with a GND line joined them at the Buffalo's end.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
