USB to I2S 384Khz - DSD Converter - Page 138 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 21st March 2013, 03:54 AM   #1371
Bunpei is offline Bunpei  Japan
I have never connected Combo384 to TPA Buffalo III.
However in general, we need to set "S/PDIF auto-detect" as "Bypass" by setting "SW2-5 ON" when we play DSD on ES9018. Have you tried this?
Old 21st March 2013, 02:22 PM   #1372
smanz is offline smanz  Spain
Originally Posted by miksi View Post
I use quite standard combination of buffalo iii dac with Amanero and WaveIO USB receivers, Ivy III, placid HD supplies, Otto II, arduino controller ... The problem I have is when playing DSD, then at the Ivy III outputs appears DC, on the left channel -1.4V and right -0.7 V. With I2S (PCM) there is no problems. The display shows the correct sampling frequency. I've checked the DC voltages and everything is fine, although I do not have an oscilloscope to see what is really going on. Oh, yes, I have the DSD sound, but is somehow clicking and crackling...
Can you play 352/384kHz. files wihtout issues?
Regards.
Old 21st March 2013, 03:09 PM   #1373
Received board, thank you
Wondering if any other users encountered issues on Windows 8? My converter/Buffalo combo worked fine (splendid in fact) on my friend's Windows 7 PC, but all it created was a loud buzzzz when connected to my Windows 8 PC. Oh well. Is there any way around it, or should I just roll back to 7?
Old 21st March 2013, 03:47 PM   #1374
Send a message via Yahoo to kannan_s
Is there a comprehensive guide to connect the Amanero board to DAC's ? as well as setting up Windows ? If some one here can document it will be easy for many who participated in the Group buy. I am wondering how to connect to Buff 11?
any specific post ?
thanks
kannan
Old 21st March 2013, 04:08 PM   #1375
glt is offline glt  United States
any specific post ?
thanks
kannan
AMANERO USB – I2S Interface | H i F i D U I N O
Also connect the ground.
www.hifiduino.wordpress.com
Old 21st March 2013, 04:21 PM   #1376
miksi is offline miksi  Serbia
Regards.
Yes and yes. I don't really have 352 and 384KHz files except couple from the 2L edition. Tiny droputs was present on first 2-3 seconds but I think it's because of the upsampler from foobar.
Anyway, with DSD files, DC output desappeared the moment I've changed quantization from 6bT to something else (with little pop from the loudspeaker) , but strangely, didn't reappear when I set it to 6bT back again,though clicking remained.
I have to put the TPA firmware chip back to try this with DSD. Jumper was already set to ON when I used WaveIO, but then I start using Arduino and removed the chip.
Old 22nd March 2013, 09:25 AM   #1377
hello everybody,
I've heard about this group buy and I'd like to know if it is still open. As far as understand one group has been closed few days ago, so a new one has just started? Which is the number of required people?
Thank you very much!
Old 22nd March 2013, 05:50 PM   #1378
Board received!
Old 23rd March 2013, 06:55 PM   #1379
ghiglie is offline ghiglie  Italy
Originally Posted by misterGI View Post
hello everybody,
Ciao misterGI,
as far as I can see here: https://docs.google.com/spreadsheet/...wYS1EcXc#gid=0
... I can see the GB5 is still opened. I'm thinking about gettin in this too, maybe we can combine the order.
Old 24th March 2013, 06:03 AM   #1380
Malvin is offline Malvin  United States
Boards arrived today. thank you very much!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
