USB to I2S 384Khz - DSD Converter - Page 134 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 16th March 2013, 02:07 PM   #1331
Originally Posted by dickiegeorge View Post
Quick question on the boards I2C connections :-
I presume the board acts as a bus master for I2C and is designed to send data to the DAC registers directly?
Therefore I can't connect it to my exisiting I2C bus which is controlling the DAC from a PIC micro (again as master)?
With a full I2C configuration of the Amanero adapter there is no need for the other I2C master.
Old 16th March 2013, 02:52 PM   #1332
Bunpei is offline Bunpei  Japan
Originally Posted by RayCtech View Post
I hope you have discovered that there is NO mono mode for DSD in the ES9018 chip and have taken the appropriate actions to rectify this
Yes, you are correct. There is no "mono mode" register setting for DSD in ES9018. We need to distribute DSD left/DSD Right signals to all channels appropriately.
I have never said "Dual mono mode". "Dual mono configuration", instead.
If you want to try DSD256/DSD512 sources, here I can tell you how to make those.
Old 16th March 2013, 02:56 PM   #1333
merlin el mago's Avatar
I want to try.
Old 16th March 2013, 03:32 PM   #1334
The software volume controls that exists cannot work with DSD without converting DSD to PCM first.
Trying to understand what you are saying here Ray. Does this mean that in my Buffalo24 because I can use the software volume control with DSD input, the DAC is actually converting native DSD to PCM? i.e that is the way DSD works in this DAC chip by converting to PCM?
Old 16th March 2013, 03:44 PM   #1335
If you use (control) the volume by programming the DAC chip registers there are no extra conversion involved, but if you use the volume control in the player app then it most possibly must convert DSD to PCM and send PCM data to the DAC.
Old 16th March 2013, 03:51 PM   #1336
Yes, but I want other inputs than just Amanero. I have implemented a controller prior to getting this board and just trying to integrate it fully....
Old 16th March 2013, 03:53 PM   #1337
Have you listened to enough DSD256/DSD512 sources on ES9018 of synchronous master clocking dual mono configuration environment?
How many sources of DSD256/DSD512 music are there?
Old 16th March 2013, 03:54 PM   #1338
Then you may be able to use 1/4 or 1/2 of the available DAC segments compared to my setup..
Are you kidding ?? That are old knowledge
Old 16th March 2013, 04:07 PM   #1339
I have a solution for that in my Dual Mono system, but it requires additional hardware (and firmware control)..
I2C - I2C Multiplexer, Switch - TCA9548A - TI.com
I am investigating a much simpler solution that also will solve this.
The Dual Mono system are also a complete analog system and uses I2C control for analog volume etc..
As I use Audum1250 (galvanic I2C isolators) between USB adapter, DACs, ADC, external I2S/I2C in and outputs and to the analog side it can be as simple as control power (power of Audum1250) to connect / disconnect the I2C masters...
Next week I can check if there are any easy solutions as the DAC I going to rebuild with the Amanero USB adapter already have a I2C (Arduino) master. And there are also a integrated SDTrans192 (I2S), a external HDMI/LVDS I2S/I2C interface (have used a exaU2I and CD/SACD player with I2S (PCM/DSD) on this port) and multiple SPDIF inputs. The SDTrans192 functions (play, >>, <<, stop, change album etc.) are controlled by the I2C master via the IR remote control as all the other functions..
Old 16th March 2013, 04:11 PM   #1340
Thanks - that looks potentially very useful.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
