USB to I2S 384Khz - DSD Converter - Page 131 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 11th March 2013, 10:28 PM   #1301
Quite a few changes in the I2C tab of the new Firmware Tool (111a):
- Changed: OnDSDEnable has been split in 4 modes (OnDSD64, OnDSD128, OnDSD256 and OnDSD512
- Changed: OnDSDDiable event has been removed
- Changed: OnModuleSelect event has been removed
- Changed: OnModuleDeselect event has been removed
- Changed: OnRateChange event has been removed
- Changed: OnVolumeChange renamed to OnVolume
- New: Slave Mode (MCLK Input)
- New: 500ms startup delay
- New: OnUnMute event
Old 11th March 2013, 11:01 PM   #1302
amanero is offline amanero  Italy
MCLK Input is working but it needs a new firmware for the cpld i haven't yet adapted for download. I think to put online the new cpld firmware soon.
When you check MCLK Input, the cpld works in slave mode and it accepts the clock from pin7. Pin1 and Pin11 are used for clock selection.
Old 11th March 2013, 11:19 PM   #1303
Will MCLK input be limited to 22.xxx/24.xxx or higher speeds will be accepted, for example 45.xxx/49.xxx?
Old 12th March 2013, 07:19 AM   #1304
it works with 45.xx and 49.xx too.
I need to add a cpld firmware selection in the maintenance tool, in this way you can choose,
cpld master, cpld slave 22/24, cpld slave 45/49
Old 12th March 2013, 08:19 AM   #1305
@jackal29a: Thanks so much for elaborating this - very helpful .. I'll look into it in the days to come and see if I can get somewhere with it.
And, yes, if a BB DAC uc programming capable person could "chip in" () on how to program the registers I'll be pleased to hear about it as well.
Greetings,
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 12th March 2013, 08:37 AM   #1306
s3tup's Avatar
It means we can use our XTALS off-board and feed them thru the connector? (with appropriate housekeeping schematics).
Oh.... boy.... i LOVE you!
What would be time tolerance between xtal frequency changes? My oscillators need some time to start-up...
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 12th March 2013, 02:30 PM   #1307
Dear Domenico:
When the GB4 will receive the board ? thanks
Old 12th March 2013, 03:00 PM   #1308
smanz is offline smanz  Spain
Is possible to swap onboard 22/24 oscilators for another 45/49 oscillators?
Any oscillator sugestion for this swap?
Onboard 45/49 oscillators make very easy reclock using Acko isolator/reclock board.
Old 12th March 2013, 09:49 PM   #1309
proffes is offline proffes  Ukraine
proffes's Avatar
Hi amanero!
I added my name on the list of this GB.
Old 12th March 2013, 11:25 PM   #1310
TNT is offline TNT  Sweden
Originally Posted by chicco_36 View Post
Actually, a lot of modern DACís have direct DSD input, the real question is how we unknowledgeable audiophiles can use them (preferably in some simple hardware mode)...
Chicco
Yes, but don't they do internal DSD -> PCM and then D/A?
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright ©1999-2017 diyAudio
