USB to I2S 384Khz - DSD Converter - Page 123 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 14th February 2013, 10:03 AM   #1221
Hi all,
So ... hopefully I'm finally close to testing my new DAC with the Amanero (DSD1794 + combo384) board but am a bit unsure of where to connect the pins ... Hope one of you can help with this ...
(I've attached a copy of the relevant datasheet page for the DSD1794)
As far as I can figure out the connections should be as this (for PCM only):
Amanero pin 3: I2S DATA/DSD1 ---> PDATA on the DSD1794
Amanero pin 4: I2S CLK/DSD CLK ---> PBCK on the DSD1794
Amanero pin 5: I2S FSCLK/DSD2 ---> PLRCK on the DSD1794
MCLK (on the combo384) or SCK on the DSD1794 is not to be used .... ?
Assistance is appreciated :-)
Greetings,
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 16th February 2013, 12:51 PM   #1222
Dear Amanero:
When should I pay for GB4 by Paypal ?
THANKS.
Old 16th February 2013, 12:54 PM   #1223
PET240 is offline PET240  Australia
peterpopo,
I believe amanero sends a pm for payment as required, so hopefully we get asked soon!
Old 16th February 2013, 01:11 PM   #1224
amanero is offline amanero  Italy
Hi, i'll send you a PM asap. I m waiting for the full batch of boards.
Sorry for this delay.
Domenico
Old 16th February 2013, 01:23 PM   #1225
Send a message via Yahoo to ThuyTN
Great
Old 16th February 2013, 09:28 PM   #1226
In the words of a fictional character......
Woohoo!
Thanks Domenico, looking forward to it.
Drew
Old 17th February 2013, 01:53 AM   #1227
supra is offline supra  Australia
I found an old Pedja Rogic TDA1541 non-oversampling dac board, is it a simple matter to connect an Amanero directly to WS,BCK,DATA,GND or isn't as simple as that?
If it is possible anyone know the corresponding connections on Amanero board.
Old 17th February 2013, 11:07 AM   #1228
deanoUK is offline deanoUK  United Kingdom
2 added to list. Thanks.
Old 17th February 2013, 12:26 PM   #1229
s3tup's Avatar
Yes, TDA1541 works with Amanero out of the box.
Connections are rather direct and intuitive -
WS = LRCLK = FS (Frame Sync)
BCLK = BITCLOCK
DATA = DATA
Don't forget to use a ground wire next to each signal wire - use ribbon with the following arrangement:
GSGSGSGSG
where S means signal and G means ground(GND).
Confirmed up to 96kHz material.
192/174kHz doesn't work as the Amanero hit TDA's limitation on BCLK frequency of 5.6MHz (BCLK=32Fs on TDA Vs BCLK=64Fs on Amanero)
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 17th February 2013, 01:37 PM   #1230
Malvin is offline Malvin  United States
Gb: increased quantity to 2. Thanks
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
