Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st February 2013, 04:31 PM   #1181
Popolvár's Avatar
+1 in GB4
Old 1st February 2013, 05:05 PM   #1182
neskor is offline neskor  Serbia
Just upgraded my Amanero board.
I have problem, how to make Foobar to play DSD files now?
Previously I was using foo_dsd_asio without problems.
Old 1st February 2013, 05:29 PM   #1183
glt is offline glt  United States
same but set output to foo_dsd_asio and in foo_dsd_asio set to asio direct
www.hifiduino.wordpress.com
Old 1st February 2013, 05:31 PM   #1184
Thanks!
That was it
Thanks also to Domenico for great support!
Old 2nd February 2013, 08:47 AM   #1185
ASIO drivers all working well here - playing back DSD and DXD just fine - thanks!
One question - is there a way to adjust the latency of the ASIO playback? This would be very useful in music production environments.
Cheers.
Old 2nd February 2013, 09:14 AM   #1186
Not that I know of. There is no control panel included in the ASIO drivers so no way to adjust it.
I've checked latency with DPCTool and ASIO under identical conditions is on average about 20ms lower than WASAPI Event in my system.
Old 2nd February 2013, 11:04 AM   #1187
OK - thanks for the info.
Old 2nd February 2013, 12:29 PM   #1188
I can report that the new driver and firmware works absolute fine including DSD in my set-up and the intermittent issues I had with playing 96k/192k files with my Linux Debian based Joggler have also gone.
Excellent work and thanks Domenico.
Old 2nd February 2013, 12:43 PM   #1189
nvduybom's Avatar
I try the external power for Amanero, I removed IC regular 3.3v and connect 3.3V/100mA to pins 3.3V on board. I measured all ok,IC regular 1.8V is ok, but PC cannot detect Amanero. Anyone try and have problem like me?.
Old 2nd February 2013, 02:46 PM   #1190
smanz is offline smanz  Spain
Amanero board must be fed after plug USB. The best way to obtain this is one relay driven by +5v of USB. This relay connect (USB plug) or disconnect (USB unplug) your external supply to Amanero board.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2013 diyAudio
