USB to I2S 384Khz - DSD Converter - Page 115 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 16th January 2013, 11:15 AM   #1141
Originally Posted by themystical View Post
Perhaps deeper, better defined bass is perceived by me as less bass.
There probably are noise issues (in the electronic measurement sense) in my system as I use a lot of valves including in the output stage of the DAC
Yes running with a 80MHz clock. Not yet tried synchronous but probably worth exploring.
As a matter of interest, which quantizer setting gives you the best subjective fidelity. Does this align with 6bT apparently giving the best theoretical SNR and THD? What filter settings do you use?
In general the higher the quantizer bit depth the better the fidelity.
True mode must be used.
Filters with highest bandwidth or no filters if possible..
Old 16th January 2013, 12:55 PM   #1142
I like this Discussion, looks like we are summarizing lots of experiences and info spread around many different websites.
Another questions:
-Anyone did percive sound quality improvement eliminating USB power supplay and using an internal DAC 3.3V source?
- I am using Buffalo III with amanero and I am looking at the Buffalo manuals to figure out if I have a 3.3V source that I can use to feed amanero, but not sure if it's worth it.
- What about those I2C isolator chips?
Cheers
Old 16th January 2013, 03:57 PM   #1143
Originally Posted by RayCtech View Post
Lower jitter = deeper bass and better defined bass.
Thus I expect your system may have jitter or noise issues.
I found this statement by Dustin Forman, the chip designer very illuminating with regard to the DPLL Bandwidth setting.(although not made in the specific context of the Sabre DAC chip)
Jitter blocking
The issue appears not to be purely about "unlocks" but also about "reading" all of the data it receives. In this context, the "Lowest" setting although providing a full lock might not be "best" setting and there may be some data loss occuring. This may also explain my perceived better bass and 'not thin sounding' at higher DPLL bandwidth settings. The "best" setting ultimately depends on your source....and getting the balance between jitter rejection and "reading all of the data" right. Anybody know the algorithm used by ESS for determining the "Best" setting in their ES9018 chip?
Old 16th January 2013, 05:18 PM   #1144
glt is offline glt  United States
Jitter blocking
From my own observations, it appears "Best" is near the high side of the scale. I think it is just a constant setting rather than an algorithm. Of course this is just based on observations.
www.hifiduino.wordpress.com
Old 16th January 2013, 06:34 PM   #1145
My listening experience would suggest that although the Amanero interface locks at the lowest settings without any issues, higher settings are required for the Sabre to retrieve all of the data. Other guys running the Amanero interface into a Sabre chip could perhaps listen to "high side" settings and post some views?
I noticed that Dustin Forman's last post was in 2011 so I guess it is not possible to get a definitive response from ESS on this forum anymore?
Old 17th January 2013, 02:57 AM   #1146
kp93300 is offline kp93300  Malaysia
Originally Posted by gioz View Post
...I have to order "High Bandwidth" Firmware chip for Buffalo-II from TP ...right??
Hi gioz,
I have B2 with this board and have occasional unlocks that decrease with warm up also..
Have you manage to solve the problem with the new Firmware chip from TP?
thanks
kp93300
Old 17th January 2013, 07:42 PM   #1147
gioz is offline gioz  Italy
gioz's Avatar
Originally Posted by kp93300 View Post
Hi gioz,
thanks
kp93300
Yes (..I hope), I'm waiting the fw from TP
Old 18th January 2013, 11:50 AM   #1148
regal is offline regal  United States
GOOD NEWS. The new intel chipset (8 series) for Haswell will have native USB2.0. I was afraid that they would go full USB 3.0 since USB 3.0 has native asynchrous mode making UAC2 and any 480mbs USB 2.0 drivers obsolete.
But the fact that intel is sticking with a native USB 2.0 we can be comfortable both on the Mac side and the PC side for many years. Anyone who has tried to run a 480bs USB interface from a USB3.0 port knows that it is NOT backwards compatible.
Old 18th January 2013, 11:59 AM   #1149
Telstar is offline Telstar  Italy
Really?
I can do the test but I remember some friends using usb3 controller cards with asynchronous USB.
Or you ment NOT in asynchronous mode?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 18th January 2013, 12:03 PM   #1150
Originally Posted by Telstar View Post
Really?
I haven't had any luck with backward compatibility of USB3 running 480mbs proprietary driver asynch. I've tried several usb boards none worked, they won't eeven run Magic Jack !
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
