| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#1101 |
Can you say Audio?
The easiest (and I think the best) way to play DSD is with Audirvana Plus. I use it every day, and it works flawlessly with the Combo384 (and every other DSD/PCM USB receiver).
#1102 |
#1103 | |
thanks for the reply. The problem in my case was the wrong output method. Apparently this only works with Kernel Streaming and WASAPI - Event Style. With WASAPI it indicates that the format is not supported. Cheers Thomas |
#1104 |
@grmx3
but how do You assume that no need for MCK, if You are went trough the PDF of AKM? Or You dint?
#1105 |
#1106 |
This is what I get when connect Amanero to Win8 PC. Any hint how to fix this ? ...seems to be a driver problem?
PSMLS CookBook by ZM |
#1107 |
Please read this wiki, it's win7 related but it can help
Fix Windows 7 Error The Configuration Registry Database Is Corrupt Errors – Windows XP, Vista & Windows 7 Cheers, Domenico |
#1108 | |
Corrupt configuration registry database - Unable to use Backup and - Microsoft Community |
#1109 | |
This seems to imply that the problem is with my PC. Could be...I'll do a checking. Anyhow, are we confident that it is working OK on Win8 configured PC's?
#1110 |
Yep it works with win8.
About the links i reported for info about this kind of error message, please don't download tools or other fix applications. Use the Windows DVD only to check and repair possible system errors. Cheers, Domenico |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 0 | 11th November 2011 11:41 AM |
| $40 USB to I2S converter | sharpi31 | Digital Line Level | 7 | 12th July 2009 04:09 PM |
