USB to I2S 384Khz - DSD Converter - Page 108 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th December 2012, 07:55 AM   #1071
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by knuisje View Post
The datasheet of the 9016 says that the MCLK can be max. 100MHz and for I2S must be min. 192 x Fs.
192 x 384000 = 73.7 MHz so a 80MHz oscillator is good enough.
But the section on OSF bypass says that 8 x Fs is recommended, sourcing data directly into the IIR filter. The maximum samplerate that can be applied is 1.536MHz (8 x 192kHz). This must be the reason samplerates > 192kHz don't work without OSF bypassing.
yes this is the same apparent discrepancy as in the 9012/8 datasheet. but with 90.3168MHz (44.1-352.4k) / 98.304MHz (48-384k) on 9012 or 9018 you can achieve 352.4/384kHz with OS enabled in synchronous mode, or with 100MHz clock in asynchronous mode, but with 80MHz its not possible
doh error before this edit. I have better experience with 256x FS is what I mean to say.
Old 18th December 2012, 11:15 AM   #1072
amolan is offline amolan  Brazil
Is there a room for one more in this list ? if positive how to proceed ?
Thanks,
Alexandre.
Old 19th December 2012, 01:40 PM   #1073
Packet received today
Grazie mille, Domenico!!!!
Old 19th December 2012, 06:05 PM   #1074
knuisje is offline knuisje  Netherlands
I made a template for drilling holes in the bottom of the housing.
Old 20th December 2012, 12:19 PM   #1075
Hi Guys,
I just bought the amanero this week and I hope i will get it in my hands soon, so now I need some advice regarding the dacs, could be a oem board or maybe a comercial one that has a dsd funcionality.
Thanks,
Alexandre.
Old 22nd December 2012, 05:22 PM   #1076
Originally Posted by Tazzz View Post
I did a small adapter PCB to conveniently replace the cs8412 in my dac with the amanero for experimental purposes.
The unmounted positions are for a LTC6655.
I did a couple of interface data jitter measurements using a 44.1khz jtest signal generated with arta measurements are here :
Another TDA1541A based dac (dual differential)
Old 22nd December 2012, 07:05 PM   #1077
nico2k3 is offline nico2k3  France
Is GB3 closed ?
Nico
Old 23rd December 2012, 04:39 AM   #1078
flyboi is offline flyboi  Malaysia
Send a message via ICQ to flyboi
I saw the GB3 is already closed on the spreadsheet. So, I just put my name there in case there is a GB4. Merry Christmas and Happy New Year.
Old 23rd December 2012, 06:32 AM   #1079
gugi100 is offline gugi100  Netherlands
I also put in my name for GB4....
Old 24th December 2012, 12:33 PM   #1080
got mine, thanks Domenico!
Looks splendid! I like the name Amanero, reminds me great Italian vine Amarone
Merry Xmas
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
