diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Vendor's Bazaar (http://www.diyaudio.com/forums/vendors-bazaar/)
-   -   "Zorin Audio" High quality Turntables and Tonearms (http://www.diyaudio.com/forums/vendors-bazaar/211529-zorin-audio-high-quality-turntables-tonearms.html)
diycoax 25th April 2012 05:28 PM
Zorin PUS-12
Zorin PUS-12 are 12 viscous damped one-point support tonearm
http://img594.imageshack.us/img594/73/pus122.jpg
http://img525.imageshack.us/img525/5554/pus121.jpg
Description:
The original patent Head shell design. Overhang, Offset angle and vertical tracking angle are all adjustable. Both sides of the horizontal azimuth counter weight adjusting device. Single Point damping tank design. Tonearm pivot point and the side of the Counter weight and hammer the same plane to reduce the shaking stable tracking. Use the ORTOFON arm cable and CARDAS 5-PIN DIN tonearm signal line connector. Separate brass plating titanium hammer. Suitable for installation of various cartridge. The high rigidity stainless steel tonearm pivot and tonearm lift is not easy to wear to ensure long-term use.
Specifications:
Type: Static-balance tonearm
Effective length: 308mm
Overhang: 13mm
Offset angle: 17.6 degrees
Mounting distance: 295mm
Cartridge range: 5-20g
Zorin PUS-9
Zorin PUS-9 are 9 viscous damped one-point support tonearm
http://img33.imageshack.us/img33/7621/pus92.jpg
http://img802.imageshack.us/img802/4563/pus91.jpg
Description:
Specifications:
Effective length: 230mm
Overhang: 18mm
Offset angle: 24 degrees
Mounting distance: 212mm
Cartridge range: 5-18g
diycoax 25th April 2012 05:32 PM
Zorin PUA-12
Zorin PUA-12 are 12” gimbal-bearing tonearm
http://img689.imageshack.us/img689/8944/pua121.jpg
http://img692.imageshack.us/img692/5998/pua122.jpg
Description:
The original patent Head shell design. Overhang, Offset angle and vertical tracking angle are all adjustable. Side of the balance centroid adjustment device. Use the ORTOFON arm cable and CARDAS 5-PIN DIN tonearm signal line connector. Separate brass plating titanium hammer. Suitable for installation of various cartridge. The high rigidity stainless steel tonearm pivot and tonearm lift is not easy to wear to ensure long-term use.
Specifications:
Overhang: 13mm
Zorin PUA-9
Zorin PUA-9 are 9” gimbal-bearing tonearm
http://img193.imageshack.us/img193/5474/pua91.jpg
http://img205.imageshack.us/img205/2332/pua92.jpg
Description:
Specifications:
Overhang: 18mm
diycoax 25th April 2012 05:35 PM
Zorin PSS-9
Zorin PSS-9 are 9” one-point support tonearm
http://img841.imageshack.us/img841/7696/pss91.jpg
http://img535.imageshack.us/img535/9251/pss92.jpg
Description:
Offset angle of head shell design. Convenient cartridge installation and adjustment. Vertical tracking angle are adjustable. Use the ORTOFON arm cable and CARDAS 5-PIN DIN tonearm signal line connector. Separate brass plating titanium hammer. Suitable for installation of various cartridge. The high rigidity stainless steel tonearm pivot and tonearm lift is not easy to wear to ensure long-term use.
Specifications:
Overhang: 18mm
Cartridge range: 5-16g
c2cthomas 25th April 2012 05:42 PM
:up::up:Wonderful looking tonearm audio eye candy!!!!
Where can we find out about purchase price etc. Do you have a website we can visit? Will you be listing yourself in the Vendors or Manufacturers forums?
SY 25th April 2012 05:43 PM
I've moved this over to Vendors'.
diycoax 25th April 2012 05:59 PM
Originally Posted by c2cthomas (http://www.diyaudio.com/forums/showthread.php?p=3000630#post3000630)
Thank you for your post.
These products direct sales from Taiwan now. I'm looking for dealers in USA or Europe.
If you interest for any product or question. you can contact me.
Best regards,
diycoax 26th April 2012 05:17 PM
Zorin music reference Linear tracking air bearing tonearm
http://img407.imageshack.us/img407/2...rencegold2.jpg
http://img835.imageshack.us/img835/3...rencegold1.jpg
Zorin music reference air pump
http://img836.imageshack.us/img836/5...rencepump2.jpg
http://img821.imageshack.us/img821/2...erencepump.jpg
Specifications:
Effective length: 53mm
Fixing distance: 230mm
Height adjustment: yes
VTA fine adjustment:26mm
Azimuth fine adjustment: yes
Air bearing: 24 x 60mm
diycoax 27th April 2012 05:09 AM
http://img706.imageshack.us/img706/5...ncesilver2.jpg
http://img403.imageshack.us/img403/1...ncesilver1.jpg
Description:
Zorin music reference Linear tracking air bearing tonearm with the short tonearm design. It has excellent tracking. Installation and adjustment are very easy. The bearing sleeve material uses the processing of high-strength aluminum alloy one piece design. The shaft material uses the processing of stainless steel with extremely high precision, while still maintaining a rigid and appearance. Air intake and exhaust vents located in the shaft. Bearing sleeve and shaft practically zero friction in movements. The lateral movement of the quality of the current market minimum. Use the ORTOFON arm cable and CARDAS 5-PIN DIN tonearm signal line connector.
Description:
Zorin music reference air pump with high flow and low noise design. Use of special isolated noise and prevent vibration method installed to the chassis. The pump does not produce oil and water, Without maintenance. Direct access to three cylinders to stabilize the pressure and reduce the airflow pulse.
Specifications:
diycoax 3rd May 2012 08:44 AM
Zorin Audio High End Turntables and Tonearms
TP-S5 TURNTABLE
http://img18.imageshack.us/img18/5004/tps5a2.jpg
TP-S3 TURNTABLE
http://img13.imageshack.us/img13/4892/tps32.jpg
TP-S1 TURNTABLE
http://img205.imageshack.us/img205/9370/tps12.jpg
Carbon mat
http://img690.imageshack.us/img690/6541/carbonmat.jpg
diycoax 3rd May 2012 08:47 AM
We are a professional turntables and tonearm manufacture company. Specializes in manufacture the High End turntables and tonearm.
We launched its own brand "Zorin Audio". Now there are many users in Taiwan, Hong Kong and Australia.
Zorin Audio is actively seeking dealers and distributors for the U.K., Europe, and Asia, the U.S. and Canada.
If you feel that our approach is a good match for your business, Please contact us to discuss becoming a dealer for Zorin Audio products.
Copyright 1999-2017 diyAudio
