ODAC offerings from Various Vendors - Page 20 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
View Poll Results: Do you want an ODAC back panel for the O2?
yes for sure! 29 43.28%
I want to use the ODAC as stand alone unit. 21 31.34%
I'd rather wait for the ODA... 17 25.37%
Voters: 67. You may not vote on this poll
Old 27th May 2012, 08:06 PM   #191
Originally Posted by everlong View Post
When you do a post, scroll down to Manage Attachment, there you can add the photos
Any thoughts on how to do this from an iPhone? I don't have my laptop with me.
Old 28th May 2012, 02:56 AM   #192
jtktam is offline jtktam  Canada
DAC / O2 order spreadsheet up
https://docs.google.com/spreadsheet/...WpvaTJ2T3FPbXc
enter the quantity you want for each item and it should calculate the total for you. For now I will charge a $15 flat rate shipping for Canada / USA and $20 flat rate for everywhere else.
everything is in stock except for the front panels, which will come early june. I have started to ship the other orders already!
-joe
our diyaudio forum - post your questions here
Audio Poutine - full web site coming soon
ODAC/O2 parts or assembled - Google spreadsheet
Old 28th May 2012, 08:47 AM   #193
Jtktam - your link does not work, "page does not exist" error.
Old 28th May 2012, 09:57 AM   #194
Sorry! for some reason the forum chewed up the url.. the corrected link is below
-joe
Old 28th May 2012, 10:06 AM   #195
please add me as paid.
hopefully in time for shipment today
thanks
Old 28th May 2012, 05:05 PM   #196
thanks
I will pack and try to get it out today
-joe
Old 28th May 2012, 05:48 PM   #197
Pics added with ODAC "crammed" inside B2-080 case with Objective 2 amp with batteries still in tact. The pics are of a test fit, I have not burnt any solder yet.
Please note, the micro "copper spool"(exposing the depth of my knowledge here). does contact the inside of the case bottom, as does the micro usb connector. Any possible issues with this?
Old 28th May 2012, 05:54 PM   #198
you need to make sure the few traces at the bottom of the odac is not going to short out the o2
also how would you make the hole for the usb? notch the plate?
-joe
Old 28th May 2012, 07:47 PM   #199
-joe
yeah, regarding the usb, I would probably drill it out and then work it with a dremel/file. I suprised it was not designed to be used in this manner as it seems to work well.
Old 29th May 2012, 08:02 AM   #200
Jelle Schrijver's Avatar
I would suspect the coil that is touching the case is not going to be a problem, since the top looks plastic (an isolator). As far as I know the outside of the USB connector is also connected to earth and can potentially cause earth loops. But that is easily heard. Else put some isolation tape on top to isolate it.
I was wondering if you only use 3 screws for the back plate, since the ODAC pcb is in the way of the screw thread in the case. And how much pressure is put on the O2 pcb by this. I would be nervous if there is pressure on the bottom near the USB connector, that this would flex the 02 pcb leading to breakage.
ODAC - European and Worldwide pre-orders swalter Head 'n' HiFi - Walter 215 8th March 2017 10:31 AM
ODAC - general and technical discussions swalter Head 'n' HiFi - Walter 96 23rd March 2014 05:54 PM
Best of eBays chinese offerings? Studio Au Solid State 92 27th February 2011 03:04 PM
Best choice of current Class D offerings for me? Racket Scientist Class D 13 3rd October 2010 12:46 AM
Copyright 1999-2017 diyAudio
