| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
| View Poll Results: Do you want an ODAC back panel for the O2? | |||
| yes for sure! |
27 | 42.19% |
| I want to use the ODAC as stand alone unit. |
20 | 31.25% |
| I'd rather wait for the ODA... |
17 | 26.56% |
| Voters: 64. You may not vote on this poll | |||
#111 |
Are schematics and layouts publicly available for this device? If so, where do I find them? If not, this is one of several promotional threads for a commercial item, and the threads will be merged and put into the Vendors forum.
If there's a sucker born every minute, where do the rest of them come from? |
#112 |
You can find the reference schematics on the XMOS page.
I am planning to create, if possible, a XMOS based DIY USB-I2S engine similiar to the Atmel based audio-widget. This will be a base module for an open-source ODAC. All of this is dependant on XMOS policy regarding their usb library. George |
#113 |
By "reference schematic," do you mean the actual full schematic of the device being sold here?
#114 | |
It appears that the 9023 clock is driven from the pin 3 output on the 7022 in this case Cheers, Dave |
#115 | |
I am hoping the group will be able to create a DIY USB->I2S board based on the XMOS cpu product. If XMOS is friendly with their audio library this may be possible. If they require restrictive licensing then a different processor will have to be looked at. The end target is an open source ODAC with full schematics and firmware available. |
#116 | |
pin 1 L/R clock pin 2 Data pin 3 Master clock pin 6 Bit clock |
#117 |
#118 |
If he is talking about the original ODAC I will have to get back to him later when I get some clarification.
#119 |
is choosing a less facetious title...
UAC2 devices should be backwards compatible, so there should be no need for doing anything but the UAC2 driver. AFAIK a UAC2 device should drop back to 'UAC1.1' at 96khz if no UAC2 support is available.
#120 | |
Last edited by qusp; 20th April 2012 at 10:10 PM. Reason: changed to slave, though its i2s master |
| ODAC - general and technical discussions | swalter | Head 'n' HiFi - Walter | 88 | 13th April 2013 10:40 PM |
| ODAC - European and Worldwide pre-orders | swalter | Head 'n' HiFi - Walter | 202 | 25th January 2013 01:32 PM |
| Best of eBays chinese offerings? | Studio Au | Solid State | 92 | 27th February 2011 03:04 PM |
| Best choice of current Class D offerings for me? | Racket Scientist | Class D | 13 | 3rd October 2010 12:46 AM |
