Intelligent Curve Tracer 3.0 release - Page 9 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 8th January 2013, 04:20 AM   #81
locky_z is offline locky_z  China
I have heard that a Chinese tracers users measured 2sk135 is also same as you, but 2sk1058 on this phenomenon.
Old 8th January 2013, 04:18 PM   #82
mos57 is offline mos57  Italy
mos57's Avatar
See the .CUV file for 2SK1058. Condition test as before: N-MOS; Vds Vs Id, Vds=36 V; RB=6k; RC=75
Old 9th January 2013, 12:54 AM   #83
Try to set options->Config->'Voltage Drop(sink)' to 2.5 or 3 , and try again.
Old 22nd January 2013, 02:19 PM   #84
buzzforb's Avatar
Locky,
No Vcc2 on collector of Q1 and 2. I have replaced Q2-4 and still no Vcc2 on collector of q1. I have not replaced q1, as i do not have any. You mentioned Q7 being a possibility, but I do not have a part number and it is a position that is difficult to see. Would you mind giving that to me so I can get it on the way.
...Shape the sound , Man!
Old 23rd January 2013, 02:35 AM   #85
The power supply to Vcc2 by PMOS//R20,
The Vcc2 have some voltage unless Q1-Q4 is shorted or R20 is break.
Q7 is the 'pnp',it between R48 and R50.
Old 23rd January 2013, 03:02 AM   #86
buzzforb's Avatar
Ill replace Q1 and go from there. Thanks.
Old 23rd January 2013, 05:48 AM   #87
To determine Q1~Q4 is shorted,you can measure Q1~Q4 Collect-Emitter resistor on board.
Old 31st January 2013, 01:01 AM   #88
buzzforb's Avatar
Locky,
i have replaced all fets. Vcc can be measured across Q2 but not Q1. Replaced Q7 with bc5xx. Still have over current lit. The base of Q7 is at supply voltage.
Old 31st January 2013, 03:03 PM   #89
Q2 Q3 collect connect Vcc2
Q1 Q4 collect connect GND
The over current led light, the reason may be:
1.Q7(2sa970) C-E is shorted or turned on
2.PMOS G-S is shorted.
if the Vcc2(Q2/Q3collect voltage) is near Vcc, but over-currebt led still light.this mean there are no over current.
Then you can short the portect_sw( it is near the over-currect led,but not install),the sw will short Q7 B-E,If Q7 is ok,then Q7 will cutoff, and the led will not light.
If LED still light, may PMOS G-S is short.
Old 31st January 2013, 04:03 PM   #90
buzzforb's Avatar
Thank You Locky, The schematic and explanation helps.
Curve Tracer Stefanoo Equipment & Tools 83 9th July 2016 01:38 AM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 09:10 PM
curve tracer? maxpou Solid State 4 24th October 2009 06:29 PM
intelligent semiconductor characteristic curve instrument locky_z Parts 14 7th November 2008 12:07 AM
Copyright 1999-2017 diyAudio
