Intelligent Curve Tracer 3.0 release - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 17th August 2013, 09:49 PM   #121
dsdjoy is offline dsdjoy  Germany
Send a message via Skype™ to dsdjoy
Default Temperature controlled curve tracing
wanted to measure my transistors at operating temperature of my class-A amp. I found a way to do this and thought I share it here. May it be useful for others
Pictures speak for themselves....
You need:
- An aluminum strip, and transistor (isolated) attached to it.
- Digital thermometer attached to aluminum strip (probe close to transistor)
- electric iron (or similar)
What needs to be determined:
I noticed from other temp measurements in real amps- where the transistors are heating up the heat sinks: When heat sinks have 50 Degree Celsius, the transistors can have 70-80 Degrees Celsius.
If you are heating the heat sinks, to simulate such temperatures of transistors, you need to take that into account.
-Oliver
Old 17th August 2013, 09:58 PM   #122
generg is offline generg  Germany
generg's Avatar
Perfect Oliver....!
and the First Wtt is......a really First Class PSS Idea
Old 18th August 2013, 01:57 AM   #123
locky_z is offline locky_z  China
I suggest use PTC heating a small aluminum,
The PTC is constant temperature. it can be detached from the 'USB Tea Coffee Cup Warmer Heating Pad'.
Old 24th May 2014, 08:54 PM   #124
Orion33 is offline Orion33  Russian Federation
Hi, Locky. My tracer stopped working. I used it last time 2 years ago - everything was right. Now turn on the JFET, load old preset, click start... Relay clicks once on and off, and on only one point of the curve with coordinates 0,I(0). What shall I do?
Old 25th May 2014, 07:55 AM   #125
In the yahoo group, I had put the newest hardware and trouble manual.
Follow the section "Curve Tracer Diagnosis" to check.
Old 25th May 2014, 09:05 AM   #126
I don't know what is yahoo group... Why do not you post them here?
Old 25th May 2014, 01:38 PM   #127
uk.dir.groups.yahoo.com/group/CurveTracer/
Old 25th May 2014, 02:56 PM   #128
I can't download
Old 26th May 2014, 03:05 PM   #129
The newest hardware manual
Old 26th May 2014, 06:39 PM   #130
Thanks, Locky. I have checked, all works as described in "Curve Tracer Diagnostic". But I can't measure anything...
Curve Tracer Stefanoo Equipment & Tools 83 9th July 2016 01:38 AM
curve tracer barclaycon Equipment & Tools 6 11th February 2010 09:10 PM
curve tracer? maxpou Solid State 4 24th October 2009 06:29 PM
intelligent semiconductor characteristic curve instrument locky_z Parts 14 7th November 2008 12:07 AM
Copyright 1999-2017 diyAudio
