L7 MOSFET AMP - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th March 2012, 04:14 AM   #21
ljm_ljm is offline ljm_ljm  China
Originally Posted by back View Post
hi can it take 75volt?
i already have a toroid i would like to use.
No problem.It can use the +-75V
Old 9th March 2012, 01:45 PM   #22
I still don't see a schematic.
Why don't you admit you don't have it or won't supply it
Quit jacking with us.
If you are going to sell amp kits, do it right.
Sam
Old 9th March 2012, 03:49 PM   #23
Circuit often changes the changes.Can not be used as the correct design.
May refer to #5.
In the KIT, not with the document.
Old 9th March 2012, 07:46 PM   #24
Let's see the correct design and do away with all the excuses.
Man!, you are dancing all around the right answer and solution.
Sam
Old 17th March 2012, 03:49 AM   #25
I have a chassis with preamp and a PSU of +-DC 53V . I have only to decide for the power amplifier and protection circuitry.
What provides better sound, an Class A / B amplifier as the L7 or a classe D as the L15D?
If you prefer the class D, which is the difference between modules and the module L15DX2 L15D (other than being double)? Why the larger size of the L15DX2 caps ? Which is better?
Old 22nd March 2012, 06:15 PM   #26
L15DX2 higher than the L15D performance difference is not particularly large.
Distortion smaller.
Analog amplifier L7, its wide range of applications. No fixed rules on the voltage.
Are free to use, L7, very durable
Old 6th May 2012, 02:49 PM   #27
augustoriodosul's Avatar
Default Very good amp
I'm using L7 to play multi amplified system with peerless 830,452 units @100Hz xover. The bass is firm, strong, very pronounced. His power is 35 VDC. Does not heat. Very good. Congratulations LJM designer.
https://www.facebook.com/media/set/?...4163418&type=1
Old 12th September 2012, 09:01 PM   #28
Default If anyone is interested...
I bought a couple of kits, reverse engineered the PCB and have created schematic. Should I publish here?
Old 23rd September 2012, 09:00 PM   #29
adiaz is offline adiaz  Spain
Distortion smaller.
Can anyone tell me what is the sound quality of the L15D?
Normally the class D sound worse treble.
What would you advise me?, Build a class AB amplifier with mosfet or buy L15D Class D.
to amplify studio monitors.
Thank you.
Old 25th September 2012, 02:34 AM   #30
I'd be interested. Yes, please.
kicker l7 help Chaoticdopey Subwoofers 5 10th December 2010 01:52 PM
kicker L7 Rebuildable? scampo77 Subwoofers 6 17th June 2009 12:57 AM
Kicker L7 rebuild audiobahnkid592 Car Audio 13 16th June 2009 07:58 PM
kicker L7 rebuildable? scampo77 Car Audio 1 16th June 2009 02:51 PM
Kicker L7 skooter Car Audio 5 26th September 2008 12:36 AM
Copyright 1999-2017 diyAudio
