| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
NPN TRANSISTOR 2N3440
![]() product details: 2N3440 datasheet pdf,2N3440 supplier,2N3440 price,2N3440 picture at UTSOURCE If you want to buy this product please visit: http://www.utsource.net/ic-datasheet/2N3440-181945.html Popular search: 2N3440 datasheet 2N3440 equivalent 2N3440 transistor 2N3440 2N3440 SILICON NPN TRANSISTORSSGS-THOMSON PREFERRED SALESTYPES NPN TRANSISTOR DESCRIPTION The 2N3440, 2N3440 are silicon epitaxial planar NPN transistors in jedec TO-39 metal case designed for use in consumer and industrial line-operated applications.These devices are particularly suited as drivers in high-voltage low current inverters, switching and series regulators. Pulsed: Pulse duration = 300 s, duty cycle 1.5 % |
#2 |
1s1588 Diode
![]() product details:1S1588 datasheet pdf,1S1588 supplier,1S1588 price,1S1588 picture at UTSOURCE If you want to buy this product please visit:http://www.utsource.net/ic-datasheet/1S1588-419634.html Popular search:1S1588 datasheet 1s1588 diode 1s1588 equivalent 1s1588 datasheet 1s1588 pdf 1S1585-1S1588 Silicon Epitaxial1 Planar Type Diode Unit in nun ULTRA HIGH SPEED SWITCHING APPLICATIONS. FEATURES: . Low Forward Voltage : Vf=1.0V (Max.) « Small Total Capacitance : CT=2pF (Max.) . Fast Reverse Recovery Time : Trrs;2ns (Max.) |
#3 |
bts723gw RON 105mΩ 53mΩ
![]() product details:BTS723GW datasheet pdf,BTS723GW supplier,BTS723GW price,BTS723GW picture at UTSOURCE If you want to buy this product please visit:http://www.utsource.net/ic-datasheet/BTS723GW-1833088.html Popular search:BTS723GW datasheet bts723gw stock bts723gw cross bts723gw ic Smart High-Side Power Switch Two Channels: 2 x 100mΩ Status Feedback Suitable for 42V Product Summary Operating Voltage Vbb(on) 7.0 ... 58V Active channels One two parallel On-state Resistance RON 105mΩ 53mΩ Nominal load current IL(NOM) 2.9A 4.2A Current limitation IL(SCr) 8A 8A General Description N channel vertical power MOSFET with charge pump, ground referenced CMOS compatible input and diagnostic feedback, monolithically integrated in Smart SIPMOS 80V technology. Providing embedded protective functions An array of resistors is integrated in order to reduce the external components Applications ΅C compatible high-side power switch with diagnostic feedback for 12V and 24V and 42V grounded loads All types of resistive, inductive and capacitive loads Most suitable for inductive loads Replaces electromechanical relays, fuses and discrete circuits Basic Functions CMOS compatible input Improved electromagnetic compatibility (EMC) Fast demagnetization of inductive loads Stable behaviour at undervoltage Wide operating voltage range Logic ground independent from load ground Optimized inverscurrent capability Protection Functions Short circuit protection Overload protection Current limitation Thermal shutdown Overvoltage protection (including load dump) with external resistor Reverse battery protection with external resistor Loss of ground and loss of Vbb protection Electrostatic discharge protection (ESD) Diagnostic Function Diagnostic feedback with open drain output and integrated pull up resistors Open load detection in OFF-state Feedback of thermal shutdown in ON-state Diagnostic feedback of both channels works properly in case of inverse current Leadframe (Vbb) is connected to pin 1,7,8,14 External RGND optional; a single resistor RGND =150Ω for reverse battery protection up to the max. operating voltage. ESD-Zener diode: 6.1 V typ., RST(ON) < 250 Ω, RST = 850 Ω typ., Rpull up = 12 kΩ typ. The use of ESD zener diodes as voltage clamp at DC conditions is not recommended Short Circuit detection Fault Signal at ST-Pin: VON > 4.0 V typ, no switch off by the PROFET itself, external switch off recommended! VZ1 = 6.1 V typ., VZ2 = 63 V typ., RGND = 150 Ω, RI = 850 Ω typ., RST = 20 kΩ typ., Rpull up = 12 kΩ typ In case of reverse battery the load current has to be limited by the load. Temperature protection is not active Open-load detection, OUT1 or OUT2 OFF-state diagnostic condition: Open load, if VOUT > 2.7 V typ. (IN low) IL(OL) typ. 2μA An external resitor can be used to increase the open load detection current Open load detection For inductive load currents up to the limits defined by ZL (max. ratings and diagram on page 12) each switch is protected against loss of Vbb. Consider at your PCB layout that in the case of Vbb disconnection with energized inductive load all the load current flows through the GND connection. Published by Infineon Technologies AG, St.-Martin-Strasse 53, D-81669 Mόnchen © Infineon Technologies AG 2001 All Rights Reserved. Attention please! The information herein is given to describe certaincomponents and shall not be considered as a guarantee of characteristics. Terms of delivery and rights to technical change reserved.We hereby disclaim any and all warranties, including but not limited to warranties of non-infringement, regarding circuits, descriptions and charts stated herein. Infineon Technologies is an approved CECC manufacturer. Information For further information on technology, delivery terms and conditions and prices please contact your nearest Infineon Technologies Office in Germany or our Infineon Technologies Representatives worldwide (see address list). Warnings Due to technical requirements components may contain dangerous substances. For information on the types in question please contact your nearest Infineon Technologies Office. Infineon Technologies Components may only be used in lifesupport devices or systems with the express written approval of Infineon Technologies, if a failure of such components can reasonably be expected to cause the failure of that lifesupport device or system, or to affect the safety or effectiveness of that device or system. Life support devices or systems are intended to be implanted in the human body,or to support and/or maintain and sustain and/or protect human life. If they fail, it is reasonable to assume that the health of the user or other persons may be endangered. |
#4 |
![]() product details:TLE6240GP datasheet pdf,TLE6240GP supplier,TLE6240GP price,TLE6240GP picture at UTSOURCE If you want to buy this product please visit:http://www.utsource.net/ic-datasheet/TLE6240GP-1010308.html Popular search:TLE6240GP datasheet tle6240gp application circuit tle6240gp application notes Smart 16-fold Low-Side Switch Features Product Summary Short Circuit Protection Overtemperature Protection Overvoltage Protection 16 bit Serial Data Input and Diagnostic Output (2 bit/chan. acc. SPI Protocol) Direct Parallel Control of Eight channels for PWM Applications Parallel Inputs High or Low Active Programmable General Fault Flag Low Quiescent Current Compatible with 3V Microcontrollers Electostatic discharge (ESD) Protection Supply voltage VS 4.5 5.5V Drain source clamping voltage VDS(AZ)max 60 V On resistance RON 1-8 1.0 Ω RON 10,11,14,15 0.35 Ω RON 9,12,13,16 0.3 Ω Output current (Channel 1-8) ID(NOM) 0.5 A (Channel 9-16) ID(NOM) 1 A μC Compatible Power Switch for 12 V and 24 V Applications Switch for Automotive and Industrial System Solenoids, Relays and Resistive Loads Robotic Controls General description 16-fold Low-Side Switch (8 x 1.3 Ω, 4 x 0.4 Ω, 4 x 0.35 Ω) in Smart Power Technology (SPT) with a Serial Peripheral Interface (SPI) and 16 open drain DMOS output stages. The TLE 6240 GP is protected by embedded protection functions and designed for automotive and industrial applications. The output stages are controlled via SPI Interface. Additionally 8 channels can be controlled direct in parallel for PWM applications. Therefore the TLE 6240 GP is particularly suitable for engine management and powertrain systems, safety and body applications. Functional Description The TLE 6240 GP is an 16-fold low-side power switch which provides a serial peripheral interface (SPI) to control the 16 power DMOS switches, and diagnostic feedback. The power transistors are protected against short to VBB, overload, overtemperature and against overvoltage by active zener clamp. The diagnostic logic recognizes a fault condition which can be read out via the serial diagnostic output (SO). Circuit Description Power Transistor Protection Functions7) Each of the 16 output stages has its own zener clamp, which causes a voltage limitation at the power transistor when solenoid loads are switched off. The outputs are provided with a current limitation set to a minimum of 1 A for channels 1 to 8 and 3 A for channels 9 to16. Each output is protected by embedded protection functions. In the event of an overload or short to supply, the current is internally limited and the corresponding bit combination is set (early warning). If this operation leads to an overtemperature condition, a second protection level (about 170 °C) will change the output into a low duty cycle PWM (selective thermal shutdown with restart) to prevent critical chip temperatures. SPI Signal Description CS - Chip Select. The system microcontroller selects the TLE 6240 GP by means of the CS pin. Whenever the pin is in a logic low state, data can be transferred from the μC and vice versa. CS High to Low transition: - Diagnostic status information is transferred from the power outputs into the shift register. - Serial input data can be clocked in from then on. - SO changes from high impedance state to logic high or low state corresponding to the SO bits. CS Low to High transition: - Transfer of SI bits from shift register into output buffers . To avoid any false clocking the serial clock input pin SCLK should be logic low state during high to low transition of CS. When CS is in a logic high state, any signals at the SCLK and SI pins are ignored and SO is forced into a high impedance state. SCLK - Serial Clock. The system clock pin clocks the internal shift register of the TLE 6240 GP. The serial input (SI) accepts data into the input shift register on the falling edge of SCLK while the serial output (SO) shifts diagnostic information out of the shift register on the rising edge of serial clock. It is essential that the SCLK pin is in a logic low state whenever chip select CS makes any transition. SI - Serial Input. Serial data bits are shifted in at this pin, the most significant bit first. SI information is read in on the falling edge of SCLK. Input data is latched in the shift register and then transferred to the control buffer of the output stages. The input data consist of 16 bit, made up of one control byte and one data byte. The control byte is used to program the device, to operate it in a certain mode as well as providing diagnostic information (see page 14). The eight data bits contain the input information for the eight channels, and are high active. SO - Serial Output. Diagnostic data bits are shifted out serially at this pin, the most significant bit first. SO is in a high impedance state until the CS pin goes to a logic low state. New diagnostic data will appear at the SO pin following the rising edge of SCLK. RESET - Reset pin. If the reset pin is in a logic low state, it clears the SPI shift register and switches all outputs OFF. An internal pull-up structure is provided on chip. Output Stage Control The 16 outputs of the TLE 6240 GP can be controlled via serial interface. Additionally eight of these 16 channels can alternatively be controlled in parallel (Channel 1to 4 and 9 to 12) for PWM applications. Parallel Control A Boolean operation (either AND or OR) is performed on each of the parallel inputs and respective SPI data bits, in order to determine the states of the respective outputs. The type of Boolean operation performed is programmed via the serial interface. The parallel inputs are high or low active depending on the PRG pin. If the parallel input pins are not connected (independent of high or low activity) it is guaranteed that the outputs 1 to 4 and 9 to 12 are switched off. The PRG pin itself is internally pulled up when it is not connected. PRG - Program pin. PRG = High (VS): Parallel inputs Channel 1to 4 and 9 to 12 are high active PRG = Low (GND): Parallel inputs Channel 1 to 4 and 9 to 12 are low active. Serial Control of the Outputs: SPI protocol Each output is independently controlled by an output latch and a common reset line, which disables all outputs. The Serial Input (SI) is read on the falling edge of the serial clock. A logic high input 'data bit' turns the respective output channel ON, a logic low 'data bit' turns it OFF. CS must be low whilst shifting all the serial data into the device. A low-to-high transition of CS transfers the serial data input bits to the output control buffer. The 16 channels of the TLE 6240 GP are divided up into two parts for the control of the outputs (ON, OFF) and the diagnosis information. Channel 1 to 8: Serial Input (SI) information consists of 16 bit. 8 bit contain the input driver information for channel 1 to 8. The remaining 8 bits are used to program a certain operation mode. Control Byte1: Operation mode and diagnosis select for channels 1 to 8 Data Byte1: ON/OFF information for channel 1 to 8 Serial Output (SO) data consists of 16 bit containing the diagnosis information for channels 1 to 8 with two bits per channel. DIAG_1: Diagnosis data for channels 1 to 8. Channel 9 to 16: Control Byte2: Operation mode and diagnosis select for channels 9 to 16 Data Byte2: ON/OFF information for channel 9 to 16 DIAG_2: Diagnosis data for channels 9 to 16. To drive all 16 channels and to get the complete diagnosis data of the TLE 6240 GP a two step access has to be performed as follows: First access: SI command: Control Byte 1 programs the operation mode of channels 1 to 8. Data Byte 1 gives the input information (on or off) for Channel 1 to 8. SO diagnosis: Diagnosis information of channel 1 to 8 or 9 to 16, depending on the SI control word before. SI command: Control Byte 1 programs the operation mode of Channels 1 to 8. Data Byte 1 gives the input information (on or off) for Channel 1 to 8. SO diagnosis: 16 bit diagnosis information (two bit per channel) of channels 1 to 8 Detailed Description As mentioned above, the serial input information consist of a control byte and a data byte. Via the control byte, the specific mode of the device is programmable. In the following section the different control bytes will be descriped. X used within the control byte means: X = L: Command is valid for channels 1 to 8 X = H: Command is valid for channels 9 to 16 1/6. LLLL XXXX - Diagnosis only By clocking in this control byte, it is possible to get pure diagnostic information (two bits per channel) in accordance with Figure 1 (page 14). The data bits are ignored, so that the state of the outputs are not influenced. This command is only active once unless the next control command is again "Diagnosis only". Diagnostic information can be read out at any time with no change of the switching conditions. Example for two consecutive chip select cycles: If the TLE 6240 GP is used as bare die in a hybrid application, it is necessary to know if proper connections exist between the μC-port and parallel inputs. By entering HHLL as the control word, the first eight bits of the SO give the state of the parallel inputs, depending on the μC signals. By comparing the IN-bits with the corresponding μC-port signal, the necessary connection between the μC and the TLE 6240 GP can be verified - i.e. read back of the inputs. The second 8-bits fed out at the serial output contains 1-bit fault information of the outputs (H = no fault, L = fault ). In the expression given below for the output byte, FX is the fault bit for channel X. To check the proper function of the serial interface the TLE 6240 GP provides a "SPI Echo Function". By entering HLHL as control word, SI and SO are connected during the next CS period. By comparing the bits clocked in with the serial output bits, the proper function of the SPI interface can be verified. This internal loop is only closed once (for one CS period). The Echo Function does not cause any internal processing of data and after the next CS signal the SO data is 0 (all registers reset). 4/9. LLHH XXXX DDDDDDDD - OR operation, and full diagnosis With LLHH LLLL as the control word, each of the input signals IN1...IN4 are 'OR'ed with the corresponding SI data bits. With LLHH HHHH as the control word, each of the input signals IN9...IN12 are 'OR'ed with the corresponding SI data bits. This OR operation enables the serial interface to switch the channel ON, even though the corresponding parallel input might be in the off state. SPI Priority for ON-State Also parallel control of the outputs is possible without an SPI input. The OR-function is the default Boolean operation if the device restarts after a Reset, or when the supply voltage is switched on for the first time. If the OR operation is programmed it is latched until it is overwritten by the AND operation. 5/10. HHHH XXXX DDDDDDDD - AND operation, and full diagnosis With HHHH LLLL as the control word, each of the input signals IN1...IN4 are 'AND'ed with the corresponding SI data bits. With HHHH HHHH as the control word, each of the input signals IN9...IN12 are 'AND'ed with the corresponding SI data bits. The AND operation implies that the output can be switched off by the SPI data bit input, even if the corresponding parallel input is in the ON state. SPI Priority for OFF-state This also implies that the serial input data bit can only switch the output channel ON if the corresponding parallel input is in the ON state. If the AND operation is programmed it is latched until it is overwritten by the OR operation. Diagnostics FAULT - Fault pin. There is a general fault pin (open drain) which shows a high to low transition as soon as an error occurs for any one of the sixteen channels. This fault indication can be used to generate a μC interrupt. Therefore a diagnosis interrupt routine need only be called after this fault indication. This saves processor time compared to a cyclic reading of the SO information. As soon as a fault occurs, the fault information is latched into the diagnosis register. A new error will over-write the old error report. Serial data out pin (SO) is in a high impedance state when CS is high. If CS receives a LOW signal, all diagnosis bits can be shifted out serially. For full diagnosis there are two diagnostic bits per channel configured as shown in Figure 1. Normal function: The bit combination HH indicates that there is no fault condition, i.e. normal Overload, Short Circuit to Battery (SCB) or Overtemperature: HL is set when the current limitation gets active, i.e. there is a overload, short to supply or overtemperature condition. Open load: An open load condition is detected when the drain voltage decreases below 3 V (typ.). LH bit combination is set. Short Circuit to GND: If a drain to ground short circuit exists and the drain to ground current exceeds 100 μA, short to ground is detected and the LL bit combination is set. A definite distinction between open load and short to ground is guaranteed by design. The standard way of obtaining diagnostic information is as follows: Clock in serial information into SI pin and wait approximately 150 μs to allow the outputs to settle. Clock in the identical serial information once again - during this process the data coming out at SO contains the bit combinations representing the diagnosis conditions as described in figure 1. Reset of the Diagnosis Register The diagnosis register is reset after reading the diagnosis data (after the falling CS edge). This is done for channels 1-8 and channels 9-16 separately depending on the previous command. By means of the control byte it is possible either to: a) control the outputs according to the data byte, as well as being able to read the diagnostic information (two bits per channel) or b) purely get diagnostic information without changing the state of the outputs or c) read back the parallel inputs plus a simple diagnosis (one bit per channel) or d) SPI "Echo Function" as a diagnosis of proper SPI function a) Serial Control of Outputs LLHHLLLL LHLHHLLL Control Byte Data Byte SI information: OR-operation valid for channels 1 to 8. SO: 16 bit diagnosis for channels 1 to 8 performed during next chip select cycle. LLHHHHHH LHLHHLLL Control Byte Data Byte SI information: OR-operation valid for channels 9 to 16 SO: 16 bit diagnosis for channels 9 to 16 performed during next chip select cycle. HHHHLLLL LHLHHLLL Control Byte Data Byte SI information: AND-operation valid for channels 1 to 8 SO: 16 bit diagnosis for channels 1 to 8 performed during next chip select cycle. HHHHHHHH LHLHHLLL Control Byte Data Byte SI information: AND-operation valid for channels 9 to 16 SO: 16 bit diagnosis for channels 9 to 16 performed during next chip select cycle. b) Diagnosis Only LLLLLLLL XXXXXXXX Control Byte Data Byte SI information: Full diagnosis for channels 1 to 8. No change of output states. SO: 16 bit diagnosis for channels 1 to 8 performed during next chip select cycle. LLLLHHHH XXXXXXXX Control Byte Data Byte SI information: Full diagnosis for channels 9 to 16. No change of output states. SO: 16 bit diagnosis for channels 9 to 16 performed during next chip select cycle. c) Read back of parallel inputs plus simple diagnosis HHLLLLLL XXXXXXXX Control Byte Data Byte SI information: No change of the output states. Read back of parallel inputs and 1 bit diag nosis for channels 1 to 8. SO:State of eight inputs plus 1 bit diagnosis for channel 1 to 8 during next chip select cycle. HHLLHHHH XXXXXXXX Control Byte Data Byte SI information: No change of the output states. Read back of parallel inputs and 1 bit diagnosis for channels 9 to 16. SO: State of eight inputs plus 1 bit diagnosis for channel 9 to 16 during next chip select cycle. d) SPI Echo function HLHLLLLL XXXXXXXX Control Byte Data Byte SI information: Echo function of SPI interface. No change of the output states. SO: During next chip select cycle the SI bits clocked in appear directly at SO because of an internal connection for this cycle HLHLHHHH XXXXXXXX Control Byte Data Byte SI information: Echo function of SPI interface. No change of the output states. SO: During next chip select cycle the SI bits clocked in appear directly at SO because of an internal connection for this cycle Parallel SPI Configuration Engine Management Application TLE 6240 GP in combination with TLE 6230 GP (octal switch) for relays and general purpose loads and TLE 6220 GP to drive the injector valves. This arrangement covers the numerous loads to be driven in a modern Engine Management/Powertrain system. From 28 channels in sum 16 can be controlled direct in parallel for PWM applications. |
#5 |
just another
If you wish to have more than one thread you can pay for a commercial forum. |
#6 | |
I wish to have more than one thread,How much should I pay? |
#7 |
2sb798 datasheet
![]() product details: UPA1478H datasheet pdf,UPA1478H supplier,UPA1478H price,UPA1478H picture at UTSOURCE If you want to buy more electronic components please visit:Buy Electronic components,Ic,Module,Transistor at UTSOURCE Popular search: 2sb798 dk 2sb798 dl 2sb798 datasheet 2sb798 pdf SILICON TRANSISTOR 2SB798 PNP SILICON EPITAXIAL TRANSISTOR POWER MINI MOLD DESCRIPTION The 2SB798 is designed for audio frequency power amplifier application, especially in Hybrid Integrated Circuits. FEATURES World Standard Miniature Package SOT89 Low Collector Saturation Voltage VCE(sat) <0.4 V (1c 1.0 A, 1B --100 mA) Excellent DC Current Gain Linearity hFE = 100 TYP. (VCE 1.0 V, IC 1.0 A) Complements to NPN type 2SD999 ABSOLUTE MAXIMUM RATINGS (Ta=25 °C) Maximum Voltages and Currents Collector to Base Voltage VCBO Collector to Emitter Voltage VCEO Emitter to Base Voltage VESO Collector Current (DC) Collector Current (Pulse) Name: 2SB798-DM Material of transistor: Si Polarity: pnp Maximum collector power dissipation (Pc): 2W Maximum collector-base voltage (Ucb): 30V Maximum collector-emitter voltage (Uce): 30V Maximum emitter-base voltage (Ueb): 5V Maximum collector current (Ic max): 1A Maximum junction temperature (Tj): 160°C Transition frequency (ft): 55MHz Collector capacitance (Cc), Pf: 36 Forward current transfer ratio (hFE), min/max: 90T Manufacturer of 2SB798-DM transistor: NEC Package of 2SB798-DM transistor: SP0 Application of 2SB798-DM transistor: Medium Power, General Purpose |
#8 |
2sb798 dk
![]() product details: UPA1478H datasheet pdf,UPA1478H supplier,UPA1478H price,UPA1478H picture at UTSOURCE If you want to buy more electronic components please visit:Buy Electronic components,Ic,Module,Transistor at UTSOURCE Popular search: 2sb798 dk 2sb798 dl 2sb798 datasheet 2sb798 pdf SILICON TRANSISTOR 2SB798 PNP SILICON EPITAXIAL TRANSISTOR POWER MINI MOLD DESCRIPTION The 2SB798 is designed for audio frequency power amplifier application, especially in Hybrid Integrated Circuits. FEATURES World Standard Miniature Package SOT89 Low Collector Saturation Voltage VCE(sat) <0.4 V (1c 1.0 A, 1B --100 mA) Excellent DC Current Gain Linearity hFE = 100 TYP. (VCE 1.0 V, IC 1.0 A) Complements to NPN type 2SD999 ABSOLUTE MAXIMUM RATINGS (Ta=25 °C) Maximum Voltages and Currents Collector to Base Voltage VCBO Collector to Emitter Voltage VCEO Emitter to Base Voltage VESO Collector Current (DC) Collector Current (Pulse) 1. Emitter 2. Collector 3. Base Maximum Power Dissipation Total Power Dissipation at 25 °C Ambient Temperature Maximum Temperatures Junction Temperature Storage Temperature Range *3 10 ms, Duty Cycle 50 % **When mounted on ceramic substrate of 16cm2 xO.7 mm Document Name Document No. NEC semiconductor device reliability/quality control system. TEl-i 202 Quality grade on NEC semiconductor devices. IE I-i 209 Semiconductor device mounting technology manual. IE I-i 207 Semiconductor device package manual. IE I-i 213 Guide to quality assurance for semiconductor devices. MEI-1202 Semiconductor selection guide. MF-1134 No part of this document may be copied or reproduced in any form or by any means without the prior written consent of NEC Corporation. NEC Corporation assumes no responsibility for any errors which may appear in this document. NEC Corporation does not assume any liability for infringement of patents, copyrights or other intellectual property rights of third parties by or arising from use of a device described herein or any other liability arising from use of such device. No license, either express, implied or otherwise, is granted under any patents, copyrights or other intellectual property rights of NEC Corporation or others. The devices listed in this document are not suitable for use in aerospace equipment, submarine cables, nuclear reactor control systems and life support systems. If customers intend to use NEC devices for above applications or they intend to use Standard quality grade NEC devices for applications not intended by NEC, please contact our sales people in advance. Application examples recommended by NEC Corporation Standard: Computer, Office equipment, Communication equipment, Test and Measurement equipment, Machine tools, Industrial robots, Audio and Visual equipment, Other consumer products, etc. Special: Automotive and Transportation equipment, Traffic control systems, Antidisaster systems, Anticrime systems, etc. |
#9 | |
just another
#10 |
Banned
![]() product details: 2N5088 datasheet pdf,2N5088 supplier,2N5088 price,2N5088 picture at UTSOURCE If you want to buy more electronic components please visit:Buy Electronic components,Ic,Module,Transistor at UTSOURCE Popular search: 2N5088 national semiconductor 2N5088 data 2N5088 equivalent 2N5088 substitute 2N5088 replacement 2N5088 vs 2n5089 2N5088 specs 2N5088 hfe 2N5088 2n5089 2N5088 alternative Amplifier Transistors NPN Silicon 1. R JA is measured with the device soldered into a typical printed circuit board. 2. Pulse Test: Pulse Width 300 is, Duty Cycle 2.0%. ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Typical parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including Typicals must be validated for each customer application by customers technical experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a sit uation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer. |
| electronic parts | joe.b | Parts | 1 | 15th December 2008 12:39 AM |
| Electronic Parts | smjohnson63 | Swap Meet | 5 | 1st February 2008 02:51 AM |
| where can I buy electronic parts? | 52remi4ever | Parts | 6 | 1st March 2007 08:06 PM |
| Arranging your electronic parts | pred | Parts | 20 | 18th November 2006 06:38 PM |
| Page generated in 0.28427 seconds (90.72% PHP - 9.28% MySQL) with 10 queries |
