DCN23BOX Digital Crossover/EQ/Room Correction - Stock Clearance Sales - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 19th February 2012, 10:21 PM   #11
Default confused...
I don't understand your outputs - a normal stereo bi-amp setup with electronic XO needs TWO outputs for each channel, (hi-pass & low). Yet yours are labeled 1,2,3+, 3-. Why is it labeled like that?? Are there 4 separate outputs that correspond to a standard setup or not?
Old 20th February 2012, 06:19 AM   #12
Robert GS's Avatar
Don't be confused...
There is 2 inputs and 3 outputs - "output 3" is both non-inverted (normal signal) and inverted. This makes it possible to drive the bass or whatever you connect to "output 3" in bridgemode if you want. It requires a stereo power amplifier that isn't already in bridged mode.
I don't see that I in any point claim that DCN23BOX is capable of stereo hi- & low-pass out. Where did you read that?
Bonus info: The DSP "onlY" holds 3 processing channels.
Best regards,
Robert GS
GroundSound.com Active Sound - Active Listening
Digital Crossovers, Power Amplifiers and DIY modules
Old 20th February 2012, 11:56 AM   #13
i didn't read that anywhere, it's simply a natural assumption to make, when it's described as digital XO/EQ/room correction. It seems to me one of the more basic features it should have.
So thanks for the explanation, and the realization that this is not suitable for my needs.
Old 21st February 2012, 12:03 AM   #14
What do you mean? The DCN23 is suitable for one channel of a 3 way, and has all the basic features you'd expect and more.
If you want a stereo 2 way, you need the DCN24.
Ground Sound
I'm considering 2 of these to replace my MiniDSP 2x8......
Old 8th March 2012, 07:26 AM   #15
DjSinae is offline DjSinae  Canada
Default Wow
sorry but why no toslink digital input in a digital crossover dsp?
I don't understand... WHY?
Digital Room Correction Project boconnor PC Based 54 4th November 2011 08:22 AM
Digital Room Correction and Foobar2000 Convolve mr.duck Digital Line Level 1 23rd June 2009 04:49 PM
DIY DSP for Digital Room Correction OzOnE_2k3 Digital Source 114 17th June 2008 08:25 PM
I need help with digital Room-correction Radian Multi-Way 1 7th February 2007 07:10 PM
Copyright 1999-2017 diyAudio
