| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
Hi folks,
I recently built a preamp with complimentary JFET input pairs and JFET output stages. It produces very low distortion and renders an elegant and sophisticated sound typical of JFETs. The project started with MicroCap simulation and was perfected with elaborate tweaking. ![]() 63308-C sch.pdf PCB layout was done with Eagle 11. ![]() 63308-C pcb.pdf Item will soon be available. Regards, US Audio Circuits |
#2 |
usacircuits.com appears to have been suspended for some reason.
#3 |
My website was attacked by hacker the other day.
The webmaster has contacted the web hosting company. Hope it will be fixed in a few days. Thanks, US Audio Circuits |
#4 |
Correction :
The PCB layout software should be Eagle 5 v11. Regards, US Audio Circuits |
#6 |
Pure coincidence, no doubt !!
I hope Erno will forgive me in this particular case for uploading his schematics, which was published at his website. Patrick (copyrighted drawing removed by moderators) |
#7 | |
jan didden
/Another new issue: Linear Audio Volume 3! |
#8 |
I've never seen this design, and I arrived at something very, very similar quite independently a very long time ago. I would proceed cautiously with this allegation. Everything I see here is prior art, and the proposed design actually differs in several key respects - I'll leave that to you to figure out.
www.kta-hifi.net |
#9 |
I have built I/V and LineAmplifier full cascoded versions with small changes to the circuits allowing of extra cascode biasings in case proper devices are not found. So far I was able to startup I/V in passive mode. Because of the reasons above I will not post a detailed circuits but can post schematics without a values, and simulation results if anyone is interested.
#10 |
Janneman,
The final MicroCap simulation shows the following result : 63308-C 1KHz.jpg Regards, US Audio Circuits |
| FS: JFET Dual Diff. DIY Stereo Preamp | Bengali | Swap Meet | 0 | 28th August 2009 05:29 PM |
| Can I use the 2N5484 jfet diff pair in an audio amplifier front end? | carpenter | Pass Labs | 27 | 28th March 2009 12:55 AM |
| Mastroianni Single JFET Input Preamp | lineup | Solid State | 18 | 4th June 2007 06:46 AM |
| Complementary diff input with JFET and BJT cascode | Bensen | Solid State | 126 | 16th October 2006 05:35 PM |
| Page generated in 0.12677 seconds (74.09% PHP - 25.91% MySQL) with 11 queries |
