Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 13th June 2011, 03:25 PM   #1
Default The new IR Class D audio chipset audio driver IC with IRS2092S
Power management technology vendors - International Rectifier Corporation (International Rectifier, referred to as IR) has introduced the use of IRS2092S integrated audio driver IC chip set, with protection of PWM (PWM) switch and IR MOSFET integrated features such as digital audio. The chipset aimed at the middle from 50W to 500W power, high performance Class D audio amplifier applications, such as home theater, home stereo, active speaker, musical instruments and professional audio applications.
The formation of new chip Class D audio solution than the Class AB design a smaller area. For example, applications in the 100W, IRS2092S IC and IRF6645 DirectFET MOSFET can be reduced by 60% of the footprint than the typical 20% reduction in material form the number of devices.
New audio driver IC architecture based on half bridge topology, integrated Class D design to achieve the required four basic functions, including error amplifier, PWM comparator, gate driver, and robust protection circuitry. Therefore, this compact 16-pin IC with a high noise resistance, can reduce the start and end of the broken sound, while greatly reducing the number of overload protection such as a very complex and expensive design work.
IRS2092S The main features include: frequency up to 800kHz analog PWM modulator with self-reset control, programmable bidirectional over-current protection (OCP), under voltage lockout protection (UVLO), and can be extended programmable preset power design dead time.
Features
• Integrated analog input Class D audio amplifier
Driver in a small 16-pin package
• Floating input half-bridge can be easily
Implementation
• programmable bidirectional over-current
Protection with self-reset function
• Programmable dead time preset in order to improve
Total harmonic distortion performance
• start and stop click noise reduction
• High interference
• ± 100 V rated output up to 500 W
Power
• up to 800 kHz in
• RoHS standards
IRS2092S IR 5USD
Old 14th June 2011, 02:14 PM   #2
Features
Implementation
• High interference
Power
• up to 800 kHz in
• RoHS standards
IRS2092S IR 5USD
File Type: jpg 1106072135ab2451ea921d4555_jpg_thumb.jpg (168.5 KB, 116 views)
Old 15th June 2011, 05:49 AM   #3
To see Huitie
Thank!
Mosfet N-Channel Audio Driver IC .... wanted qsa Chip Amps 1 9th November 2008 06:07 AM
class D audio power amplifier using tas 5261 IC. surya krishna Class D 14 5th July 2007 12:14 PM
Class A vs. IC amplifiers for PC audio Beggar Solid State 15 26th July 2002 11:58 AM
Page generated in 0.08779 seconds (75.97% PHP - 24.03% MySQL) with 11 queries
