hypex ncore - Page 92 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th December 2011, 07:20 PM   #911
Originally Posted by Bruno Putzeys View Post
Since ESL's are almost entirely reactive, no net power is drawn.
That implies that ESL's have much higher transduction efficiency than other direct radiators (which os on the order of 1%); do they?
Noah
Old 20th December 2011, 07:58 PM   #912
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Well, half under the flu anyway, so started reading this thread. cost me about an afternoon. Sort of gave up after the AP2 riot, glad that is over.
Not glad about the NC400's being sold out. If only I was aware earlier ...
@Jan-Peter, Bruno,
After some years playing with the UcD;s (i think I have one of the earliest model ucd400's), it "might" just be time for an upgrade, any ideas as to when the next batch will be available?
Ah yes, and one other question, the modules being round, does that have a specific reason (except for, of course, coolness ) ?
edit: some typo's and rephrased some stuff
Si fractum non sit, noli id reficere!
Old 20th December 2011, 08:17 PM   #913
I believe sometime January is when we can expect the next batch.
Old 20th December 2011, 08:22 PM   #914
matjans's Avatar
... I've noticed that differential inputs (and what benefits they have over single-ended) still elude some people ...
And that's apart from the gain.
Not to mention that many, including me, don't have differential outputs.
So unless I put a hacksaw to my ssp-300 ...
Old 20th December 2011, 11:33 PM   #915
@Jan-Peter, Bruno,
here's your answer
forum.zelfbouwaudio.nl • Toon onderwerp - Hypex Ncore
it's my life
Old 21st December 2011, 01:29 AM   #916
stokessd's Avatar
I am using the 180 modules with my Quad 63's and they are outstanding. I've also got the icepower 125ASX2, and three of four different Tripath chip amps. The Hypex bests them all nicely. I also have a push-pull EL34 amp that is damn nice, but I'm using the Hypex amps these days and the other amps sit on a shelf.
The Hypex amps are also great on my DIY electrostatic speakers which are a nasty load, worse than the 63's.
You wanna hear nasty, try a adcom 535 on an electrostatic loudspeaker...
Sheldon
Old 21st December 2011, 07:34 AM   #917
That precisely is one of the great and ineradicable misconceptions I want to rectify. You do not need differential outputs. Even single ended outputs are already differential: one terminal is driven, the other is ground and the signal is the voltage difference between them. The point of a differential input is that it has an explicit reference pin which is not connected to its local ground so you can use it to sense the ground potential at the source.
The NC400 is round for No Reason At All. The first batch sold out within 5 hours, the next is due in January.
There's a time for everything, and this is not it.
Old 21st December 2011, 08:14 AM   #918
jmbulg is offline jmbulg  Belgium
I guess the design was done in a pub around a pint and on the beer mat (usually round)
As for sold out, I suppose we will soon see a few of the lucky buyers show their implementation ?
Old 21st December 2011, 08:55 AM   #919
matjans's Avatar
Ah, you got me, mixing up differential with symmetric. My humblest apologies.
Point is that many people (including me) mix up terminology. Differential, balanced, symmetric etc.
Thanks for pointing that out.
Old 21st December 2011, 09:02 AM   #920
back is offline back  Greece
bruno can you explain this better?
especially the "one terminal is driven" part?
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
