Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th December 2011, 06:54 AM   #801
@julf The NC is more efficient (especially idle dissipation) and drives low impedance loads better. Future revisions of the UcD400 will incorporate these changes (the latest UcD400OEM already does).
Most listening reports that are already "out there" are in Dutch, for obvious reasons. I notice that some of the people waiting to hear third party reports are Dutch too so they might actually be able to read them.
There's a time for everything, and this is not it.
Old 15th December 2011, 07:14 AM   #802
If we who are so unfortunate not to read dutch, are so fortunate that some who can read dutch, will report in English what they read, we sure will be very grateful, indeed .
Bruno, please spread the word, when you expect the next batch to be available.
As for the data sheet questions, it would be great if you could specify the expected current demands for the input buffer stage supply. It could be helpful for we who are to specify a linear supply.
- You have shared the voltage demands, but current may be relevant too, especially as you earlier mentioned that it was expected to draw a lot more current than the UCD series buffers, hence the need for a lower voltage supply than that for the output stage.
cheers,
Old 15th December 2011, 07:15 AM   #803
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi all,
Here's a link, Dutch NCore review:
Hypex NCore review
Rudy
It’s not what you know, but who you know “and where they are”
Old 15th December 2011, 07:38 AM   #804
deandob is offline deandob  Australia
Retrofitting into a case built for the UCD400's doesn't look like fun with the circular PCB, any information on how the mounting works, it looks like the heatsink attach is on the bottom of the board?
Also when will the second production run be available for sale?
Old 15th December 2011, 07:44 AM   #805
The NC400 is mounted on a rond heatsink, mount this heatsink flat inside your case. There are holes in the heatsink with M3 thread for easy mounting.
The end of January we'll have the next batch available.
Old 15th December 2011, 07:51 AM   #806
StigErik's Avatar
Do I understand it correctly when I say that the NC400 under normal conditions does not need an extra heat-sink? It can be free-air cooled, provided proper circulation of course?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 15th December 2011, 07:56 AM   #807
Bruno did - once more - launch a killer !
Congratulations
Charles
Old 15th December 2011, 08:01 AM   #808
Julf is offline Julf  Europe
Bruno, you are not making my decisions any easier
Any guesstimates on the time frame for the improved UcD400?
Old 15th December 2011, 08:25 AM   #809
Originally Posted by abraxalito View Post
Tells me you guys aren't so happy with the sound of ucD perhaps? Will you all be putting your old ucDs up on ebay or using them in secondary systems around your home?
So I guess people at the Pass forum must be really pissed off with Mr. Pass and his creations... They keep building his newest stuff!
Old 15th December 2011, 08:27 AM   #810
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Translation from the link provided by BMW850.
Ik ben reeds lange tijd bekend met de UcD producten van Hypex; veel mensen om me heen bouwen verstekers met deze modules. Ik ben van mening dat de UcD de beste kwaliteit versterking biedt voor het gestelde prijs niveau. Desalniettemin (en zonder de prijs in aanmerking te nemen!) vind ik zelf de UcDs een concessie. Ondanks het correcte tonale karakter ontbrak voor mij ergens de energie die ik in live-muziek altijd zo waardeer. Voor mij is het belangrijk dat wegstervende tonen evenveel opvallen als de aanzet daarvan, en bij de UcDs heb ik altijd het gevoel dat er meer accent op de aanzet zit (PS, een combinatie van een UcD met een Borbely voorversterker brengt hier een stuk balans, energie en bezieling, zonder de sterke eigenschappen van een UcD aan te tasten).
De Ncore zet hier de puntjes direct op de i. We hebben nu niet alleen de tonaal correcte balans, de precisie en aftekening zoals we die met de UcD gewend zijn, maar ook de energie balans lijkt helemaal te kloppen. De combinatie van enorme controle en harmonische rijkdom van instrumentarium grijpen je naar de keel. Alle bronnen blijven over het hele spectrum ram vast in hun 3D beeld staan, van diep laag tot hoog. Het hele gezelschap was duidelijk onder de indruk. De ene CD naar de andere CD ging de lade in, en als je ziet dat mensen CD titels op aan het schrijven zijn tijdens een demo, dan weet je eigenlijk dat het goed zit.
M.a.w., mooi product, en zeker iets om te overwegen!
I am quite familiar with the UCD product line by Hypex. A lot of people are building amps with the UCD. It is my opinion that you cannot have a better sounding amplifier than the UCD at that price. But without taking the price into consideration I found the UCDs to be compromised. Despite the correct tonal character of the sound. I always found the energy from a rendition of live music lacking with the UCDs. To me the attack and the decay of this type of music is equally significant. And the UCD seemed to emphasize the attack more than the decay. (The borbely preamp in combination with the UCD seemed to restore some of that balance)
The NCore dots the i's and crosses the t's. Not only is the tonal balance, precision and delineation correct as we have become accustomed to with the UCD. But the "energy balance" is now also correct. The combination of complete and utter control and harmonic richness of the instruments grab you by the throat. All point sources (instruments?) remain rock solid in the same spot in the 3d canvas from the lows to the highs. The assembled listeners were clearly impressed. One after the other CD was listened to. And if you see folks writing down titles of the CDs you know all is well.
In other words a great product, definitely worth considering!
Probably the hardest part to translate was "mooi product". Literally translated it means beautiful. A beautiful product. But in English beautiful refers more to the look. In Dutch it refers more to the whole thing.
Hypex problem, who can help Hansms Class D 8 10th March 2011 08:18 PM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Copyright ©1999-2013 diyAudio
