hypex ncore - Page 739 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 3rd December 2013, 04:57 PM   #7381
Julf is offline Julf  Europe
Originally Posted by Toaster View Post
Linn Isobariks. Mostly KEF drive units though.
Indeed. I have been told that the first ones were built using 2 KEFkits per box.
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 3rd December 2013, 04:58 PM   #7382
troystg is offline troystg  United States
troystg's Avatar
Ahhh. 'splains it...
Thanks.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 19th December 2013, 03:17 PM   #7383
Drsah is offline Drsah  Slovenia
What is recomended input power on xlr for hypex? 4Vrms or 8Vrms?
Old 19th December 2013, 03:19 PM   #7384
OllBoll is offline OllBoll  Sweden
When I calculate mathematically with 26 dB gain 2 Vrms should become ~ 40 Vrms, and 40^2 / 8 is about 200 which sounds about right.
EDIT: I checked an answer by Bruno and 2 Vrms it is for full power, at least into 8 ohm.
Old 19th December 2013, 03:27 PM   #7385
So, 4Vrms on xlr is enouh if i have 8ohm speakers.
8Vrms is too much.
Old 19th December 2013, 03:27 PM   #7386
As OllBoll says - 2Vrms is the upper limit for input amplitude/voltage (not power), unless you modify or remove R141.
Old 19th December 2013, 03:29 PM   #7387
8Vrms is too much.
Even 4 V is too much (doesn't matter if it is on an xlr, rca or whatever connector). If you want to drive it with 8V, you have to remove or replace R141.
Old 19th December 2013, 03:32 PM   #7388
So yes, 4 Vrms is enough by far. Your ears will probably bleed before you run out of power =)
Just make sure you don't send a full 4 Vrms signal to the NCore since the speaker ( and your ears ) might not like it very much.
Old 21st December 2013, 12:43 PM   #7389
Omholt is offline Omholt  Norway
Paul McGowan:
Me, I am just a designer who knows what he hears. What I hear is a far more open transparent sound signature when there is less feedback in the input stage of an amplifier.
Going against the grain | PS Audio
"Far more transparent" then Ncore? That's strong words and difficult to take seriously.
Old 21st December 2013, 02:06 PM   #7390
Originally Posted by Omholt View Post
Paul McGowan:
There was no comparison to Ncore mentioned in PM's post. The amplifier Mr McGowan is working on uses a proprietary input stage, coupled to a uCD output stage. Hopefully the new 0 NFB input stage will bring this amp to the next level, and I am interested in hearing it.
Hypex problem, who can help Hansms Class D 9 18th August 2013 06:49 AM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
