hypex ncore - Page 716 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th September 2013, 06:12 PM   #7151
Julf is offline Julf  Europe
Originally Posted by Juhleren View Post
Arcam DVD capable of HDCD decoding vs Naim CD5 only 16 bit decoding.
Actually, your description is pretty much exactly what can be expected if playing a HDCD-encoded recording on a non-HDCD-aware player. See HFN: The HDCD Enigma
"One curious consequence of this is that if the listener tries an HDCD with soft peak limiting on two players – one HDCD and the other CD – they may not like the uncorrected distortion (introduced by HDCD recording) when played on the CD player. So such a comparison may give an impression that HDCD is inherently ‘better’, when in reality a normal CD made of the same source material might also have sounded much better than the HDCD played on the CD player. In essence, the use of the peak alterations may cause CD replay to sound ‘worse’ rather than show HDCD as genuinely ‘better’."
Yes, absolutely no "absolute" in the world of hifi or the world in general.
The way I read you, is that this is relative -meaning that when looking at the probable loss in information it is relatively small in comparison to other losses/distortions/deformations of the digital signal, right?
If I read you right, an important assumption must be that these types of deformations of the signal are comparable not just quantitatively, but also qualitatively in terms of how we perceive them. Of course if this is true, we can disregard looking at sources of signal deformations that should be "hidden" in other types of limitations. Practically speaking, time and money should be better spend somewhere else. Am I still on the right track?
Definitely.
When relating this to the digital domain, my question is that how can we be sure that the same thing is not happening -that quantitatively small sources of distortion can still bare significant audibility, although other apparent limitations should seem much larger?
Nothing is ever 100% sure, but a heck of a lot of research, and pretty massive controlled listening tests have been done by Bell Labs and others.
Please excuse my ignorance on this subject, but would the argument be that because digitalized information IS nothing but quantitative levels, nothing can possible be "hidden" between these levels? And therefore we should be able to go as far to reduce the bit depth to the dynamic range of the signal, right?
Right.
Dithering, I am not qualified to discuss, but from my understanding it is a method that works by introducing low level noise to the signal in order to modulate the bit depth of the signal from say 16bits to 24 or even 32? How does this method actually alter the quantized levels of the source material into more bit depth? I assume it must somehow be adding information that was not present in the source material, right?
It doesn't add anything that wasn't there, but it shifts the noise. There is a pretty good illustration here: Australian Hifi: What is Dither?
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 15th September 2013, 07:28 PM   #7152
Once again I am recommending Monty Montgomery's Digital Show & Tell, the part about dither is quite illustrative.
If you don't have the time or patience to watch the video, there is a text version as well, but actually seeing the waveforms is an educating experience.
Old 15th September 2013, 08:08 PM   #7153
Thanks again Julf!
I don't have the time right now, but will take a look at your recommendations as soon as time allows me to
all the best,
Old 16th September 2013, 09:59 PM   #7154
Send a message via Yahoo to mr_push_pull
I think you're misunderstanding dithering, it's not something that fixes what is broken, it prevents the signal from "breaking". once you sample w/o dither it's done and over with, you can't get data back.
I don't think it's possible to really prove that dithering is "perfect" because it would require an absolute understanding of human hearing.
the best way to understand it intuitively is this: think of a sine wave that's sampled with say 3 bits resolution, 1 bit corresponding to 1 volt. obviously you can't encode say 3.6 volts that way, only 3 and 4 is possible. but if you add noise, you'll actually be sampling 3.6+x (where x is the dither). the result will either be sampled as 3 (x<0.4) or 4 (x>=0.4). but statistically it will be 3, 4 times out of 10 and 4, 6 times out of ten. which averages to... 3.6.
the only plausible argument against dither is that the ear/brain system is not actually perceiving the averaged but that instandaneous value (3.6+x, in our case) but as far as current understanding goes that's not the case.
we all love a good ol' stereotype until it's against us
Old 18th September 2013, 05:08 PM   #7155
reading up more on this, does anyone know off hand what the value of R141 is? I am running 101db sensitive speakers, and i want to either remove it, or lower the value so that gain is lower.
Old 18th September 2013, 08:35 PM   #7156
1.2K.
To quote Bruno: "Not much has changed since http://www.hypex.nl/docs/appnotes/gain_appnote.pdf
Gain is 4.17*(1+2*Rf/Rg). Rg=1.2k, Rf=2.2k. Rg, as noted in the bugs section of the data sheet is not marked (will be in the future), but it's called R141 and it's the one furthest to the left of the input connector. The maximum gain reduction you can get is 13.4dB, which is when you remove R141 altogether."
Old 18th September 2013, 09:34 PM   #7157
Default ?
Julf, I am doing something wrong perhaps? But, using that formula with Rg=1.2, I end up with a gain of ~19.5? That does not seem right at all, as gain of the Ncore is supposed to be ~26?
Old 19th September 2013, 03:57 AM   #7158
mogn is offline mogn  Denmark
26db = 19.5 gain
Old 19th September 2013, 05:54 AM   #7159
A voltage gain of 19.5 equals 25.8 dB.
Old 24th September 2013, 04:38 PM   #7160
Tobi F is offline Tobi F  Germany
maybe its a stupid question.
But are there any other NCore modules planned for DIY ?
NC180 would be nice for active systems.
Cheers
Toby
Hypex problem, who can help Hansms Class D 9 18th August 2013 06:49 AM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
