hypex ncore - Page 69 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 5th December 2011, 04:34 PM   #681
@back The spikes I'm talking about are in the time domain. I was trying to explain to Juhleren that these don't happen on speakers that are impedance corrected (such as yours, apparently). The story is this: imagine a speaker with a strong impedance maximum. Now run the speaker with a sinewave at that frequency. Current will be minimal because the back EMF is in phase with the amplifier output voltage and has nearly the same amplitude. Now suddenly reverse the phase at the peak of the sine wave... That creates a current spike which is much larger (up to twice as large) as the maximum current you would get with a continuous sinewave at an impedance minimum. The worst case point is the impedance maximum, not the minimum.
Now what happens when you place a conjugate network in parallel with the woofer is that this network will deliver this peak current, thus making the job easier for the amp. If the impedance measures like a resistor, it will behave like a resistor, no matter what kind of signal you feed it.
@juhleren: the module, as it stands, current-limits at 24 amps.
There's a time for everything, and this is not it.
Old 5th December 2011, 04:43 PM   #682
Julf is offline Julf  Europe
So better have *at least* 2.5 mm2 speaker cables...
Old 5th December 2011, 05:03 PM   #683
back is offline back  Greece
it`s clear now.
i agree corrected speakers are easier load.
mine are just inefficient.
julf i have 6mm.
Old 5th December 2011, 06:43 PM   #684
adelias is offline adelias  Greece
The would consider the description "just inefficient" to be a massive understatement for speakers that require Hypex UcD2k modules to perform acceptably.
Old 5th December 2011, 06:58 PM   #685
Originally Posted by RockLeeEV View Post
At VLF your best bet is to throw more surface area at the problem, not more heat.
Yes, but only if the surface area is backed by more box volume.
Originally Posted by back View Post
my findings are that at 200hz where the xover point is 60% of the power needed is at mid high section.
theory confirms that as i found out that the 50% xover point is 300hz.
That’s probably true if the transduction efficiency is equal across the band, but even using bass drivers with the same nominal efficiency as mids/tweeters, the efficiency at the low end is almost always limited by box volume.
… imagine a speaker with a strong impedance maximum. Now run the speaker with a sinewave at that frequency. Current will be minimal because the back EMF is in phase with the amplifier output voltage and has nearly the same amplitude. Now suddenly reverse the phase at the peak of the sine wave... That creates a current spike which is much larger (up to twice as large) as the maximum current you would get with a continuous sinewave at an impedance minimum. The worst case point is the impedance maximum, not the minimum.
I don’t see the relevance in practice; such a sudden reversal cannot occur in a LP-filtered bass driver - correct?
Noah
Old 5th December 2011, 08:43 PM   #686
Thanks for the comments, Bruno.
Most often i find impedance correcting filters to be employed in mid and tweeter slopes rather than in woofer slopes. The speaker in question seems to use a another strategy too which is to parallel the 4ohm coil with a low impedance coil to utilize the FS peak rather than just level it and burn the current to heat. Unless you by "a conjugate network in parallel with the woofer" mean this parallel VC arrangement of course :-)
Of course even more off topic, but most sane speaker builders would instead use a reflex port tuned to match the in box impedance peak of the woofer thus limit excursion and increase sensitivity while reducing the impedance peak. This would of course shorten the hunt for an adequate amplifier ;-)
What I canīt get my head around is how a 3ohm impedance speaker is forcing a UCD700 in its knees eventhough its sensitivity is only 87dB. The UCD should be able to deliver near full voltage unless something fishy is cooking around in that speakers dynamic behavior -even though it in theory should behave like a resister as which is measures like. We are talking peaks of around 1600W!! I canīt imagine how those drivers can eat that unless most of it is lost in the (highly engineered) filters or it is in fact the speaker that struggles at those power levels...
Old 5th December 2011, 08:45 PM   #687
not exactly true.
ucd700 sound really good too.
ucd2ks have a small improvement.
Old 5th December 2011, 08:56 PM   #688
going with bass reflex would require double box volume.
the efficiency of the speaker is 87db with 2.83 volt so 1 watt will be
84db.
on top of all these my ucd700s are powered a bit at the low side 75volt
so they can`t deliver the full 700watts but something like 600-630 watts.
Old 5th December 2011, 09:20 PM   #689
back,
I deliberately said sensitivity and not efficiency. But yes peaks in the area of 1600W (70V@3R) is only translated into acoustic output with an efficiency about 84 (if the speaker was 4ohm, which it isnīt) so we are really talking about 83dB if we are arguing over a trifle here :-)
A 1000W peak should still give you 113dB peak. If not your speakers are probably compressing due to heating of VCs and motor systems.
If you find the UCD2k with more grunt and worse distortion to sound better than the UCD700, isnīt the nCore the wrong way to go as it has both way lower distortion and lower power specs too?
If the nCore is happy with 1,5R loads you may find them usable in a bridged config, but remember that also nCore like UCDs seem to perform lower distortion at higher impedances hence you may not achieve much by bridging into so low impedances...
Hmmm, its probably wisest to go with Brunoīs advise here as your speakers seems out of the ordinary and very very different from what i have experience with...
cheers,
Old 5th December 2011, 09:27 PM   #690
Not really if the woofers were designed for reflex usage (as most are today). Comparatively you will get more output in a smaller box if both woofer, box and tuning is designed properly(hence higher sensitivity and efficiency).
Using a high Qt driver for bass reflex will of course not enable you to use a smaller box but with a larger box you will also go way lower. Closed boxes were the thing back when woofers couldnīt get the Q down. Its religious of course, some just believe in closed boxes and some donīt...
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright Đ1999-2016 diyAudio
