Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 27th January 2013, 09:48 AM   #6211
Omholt is offline Omholt  Norway
If anyone gets to compare Firstwatt SIT-1 with Ncore, please share.
FIRST WATT S1
Old 27th January 2013, 10:19 AM   #6212
StigErik's Avatar
Originally Posted by Omholt View Post
Ncore is a wonderful amp that put my search at ease. I do wish Hypex would release a Ncore with less watts though. I don't need 200W in an active system with a high sensitive compression tweeter.
Bruno explained why this is not sensible a couple of hundred pages ago. Main points were that a lower power amp would have higher distortion, and would not be any less expensive. It would not have lower noise either, so there is really nothing to gain ...
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 27th January 2013, 10:40 AM   #6213
ds23man is offline ds23man  Netherlands
Just try a series resistor! You will see it works like charm!!!!!
Old 27th January 2013, 11:51 AM   #6214
Ok. Thank you for the information.
Think I will stick to UcD for my hometheater speakers then. Too expensive with Ncore everywhere.
Old 27th January 2013, 01:57 PM   #6215
Julf is offline Julf  Europe
Old 27th January 2013, 02:32 PM   #6216
Send a message via Yahoo to mr_push_pull
Originally Posted by hifial View Post
developed recently, a linear loop technology known as AMS, (Adaptive modulation Servo), which is phase shift modulation, eliminating all feedback in the circuits, rather than pulse width modulation, which has been around for forty years.
looks like he used the Star Trek technobabble generator: Technobabble Generator
I'm currently designing a verteron neutrino device, based on the rapid particle phenomenon, employing thermal nano-capacitor technology in order to achieve a perfect ionic particle harmonic.
so, class D gurus... better watch out.
we all love a good ol' stereotype until it's against us
Old 27th January 2013, 03:40 PM   #6217
Worked on that for a while. The modulated alternating actuator and the reciprocating frequency controller don't get along very well unless you get the oscillating frequency matrix right. So, make sure you double-check those numbers before applying power.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 27th January 2013, 03:44 PM   #6218
And don't forget the series resistor!
Old 27th January 2013, 03:54 PM   #6219
+1
Series resistors are very important in a oscillating frequency matrix, if not used the rapid particles will start to move upwards instead of sideways!
Old 27th January 2013, 04:27 PM   #6220
Hypex problem, who can help Hansms Class D 8 10th March 2011 08:18 PM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Copyright ©1999-2013 diyAudio
