hypex ncore - Page 615 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th January 2013, 01:12 PM   #6141
Banned
Originally Posted by robbbby View Post
What about biamping with using one smps per 2 ncores versus biamping and using a smps for each ncore?
On the paper, it is better to use separated SMPS.
In real world, my experience tells-me the contrary. And i tend to prefer one SMPS for the two stereo channels as well, instead of the hype two mono blocs configuration.
The reason is that the supplied voltage tend to collapse a little during transients. even with the best regulated SMPS.
In monoblocs configuration this affect only one channel, if the transient is only on this one: your stereo image will move during this transient. An unique SMPS will keep the stero image stable, because the overall gain will stay equal between the two channels. So for multi-amplification of active speakers, in regard to bandwidth coherency. On that point of view, passive filtering gives more natural results for the same reason. But active present other advantages.
Chose your poison.
Old 20th January 2013, 01:52 PM   #6142
My Hypex for Sale in Germany. New built with WBT speaker terminals, silver wire and Furutech XLR terminal. Updated XLR cable.
Send me a private message for pictures, price and questions.
Marybety
Old 20th January 2013, 01:55 PM   #6143
Originally Posted by mike_mcf View Post
...one supply is capable of powering amps to full power.
Depends on the load.
Obviously a single 600W supply will be a bottleneck if two NC400s (try to) dish out 400W or, even worse, 600W each (@4R and 2R respectively, 1% THD).
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 20th January 2013, 02:17 PM   #6144
Yes I suppose. I have difficulty imagining that a 400w amp would be power limited in a home environment though (and I listen loud).
Michael
Old 20th January 2013, 02:27 PM   #6145
akasha is offline akasha  Denmark
some have far less than 1% efficient speakers, hence the discussion about bridging the ncore some pages back in this tread
Old 20th January 2013, 02:39 PM   #6146
ds23man is online now ds23man  Netherlands
ds23man's Avatar
Haha, I had two of those running at 4 30cm Dynaudio woofers per side ( 2 Ohm):
http://www.crownaudio.com/media/pdf/...O2000_Broc.pdf
Old 20th January 2013, 02:48 PM   #6147
Just curious, knowing other Crown amps capability in the low end:
do you feel the ncore have as much "grip" and authority driving direct radiator woofers as Crown?
Old 20th January 2013, 02:53 PM   #6148
pos is offline pos  Europe
pos's Avatar
That particular crown amp looks quite special...
http://www.crownaudio.com/media/pdf/...n%20Manual.pdf
page 12:
Old 20th January 2013, 03:29 PM   #6149
Julf is offline Julf  Europe
Really?
As long as the amplifiers are not so close to their maximum output that they are clipping, the output will be independent of the power supply voltage (the supply ripple rejection of the nc400 is specified as at least 75 dB, the "near-static" power supply voltage variation rejection is probably much higher still.
75 dB means a 10% in the supply voltage will cause an output variation of 0.002% of full scale...
Old 20th January 2013, 03:47 PM   #6150
ds23man's Avatar
Can't tell, it is more than 10 years ago I owned this Dynaudio M4 4 way active studio monitor ( I build it myself). But one thing I can tell, those Crowns where awesome....... 32 output devices and 41 Kg ( monoblock)
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
