hypex ncore - Page 604 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 17th January 2013, 04:28 PM   #6031
ds23man is offline ds23man  Netherlands
So maybe we can conclude it is wise to solve the hiss problem on compression drivers with "something" between the amp and driver instead of f..king around with the Ncore?????
Old 17th January 2013, 04:40 PM   #6032
Esperado's Avatar
Originally Posted by Julf View Post
I am aware of the fact that English isn't the native language of either of us, but I do not understand what you are saying here.
Sorry for my poor English.
When the moving coil moves inside the magnet gap, it create a current /tension (motional). More the QTS of the speaker, more it is. And a high efficiency horn is a high efficiency microphone.
This signal is seen by the amplifier, and will be added in the feedback loop of the amp. Any resistance in serial with the driver will create an attenuator with the very low impedance of the amp, and eliminate this. Low impedance cables helps to dump the bass cone speakers resonances, no need for a horn driver.
Yes :-)
More than that, as the Ncore is a class D amp, it would be stupid to loose its definition. Limiting its power is like reducing a digital delta sigma DAC to the first bits, in a way. The good way to adapt its power would be to reduce the power supply voltage.
Ultimate Protection and more.The Only Source of Knowledge is experience, everything else is just information” ©A. Einstein
Old 17th January 2013, 04:41 PM   #6033
Julf is offline Julf  Europe
Maybe we can conclude that each one of us can do whatever we want with our Ncores? This is diyAudio after all, and there are no absolute reasons for one solution over another...
Old 17th January 2013, 04:43 PM   #6034
Thank you for the clarification!
Old 17th January 2013, 04:54 PM   #6035
jlaakso is offline jlaakso  Finland
Which one? (just out of curiosity)
hifiharrastajat.org
Old 17th January 2013, 05:17 PM   #6036
Originally Posted by jlaakso View Post
hifiharrastajat.org
Wasn't familiar with that one - haven't lived in Finland for 15 years. But the cover of the magazine from -89 was a nice nostalgic reminder - I got my Linn Isobariks (still going strong!) from Kruunuradio around that time...
(apologies for the totally OT ramblings of an old expat)
Old 17th January 2013, 05:26 PM   #6037
pos is offline pos  Europe
pos's Avatar
Gain adjustement (either up or down) has always be a documented feature in Hypex amps, nothing wrong with that... (when you know what you are doing)
Old 17th January 2013, 05:43 PM   #6038
Everybody can do what he wants, but making decisions on wrong assumptions should be avoided ( and can lead to serious damage). The first wrong one, and will not point a finger, is the preservation of the damping factor in use with a horn( aka compression) driver..........
Old 17th January 2013, 05:47 PM   #6039
Horns don't make any exception to preserving damping factor - while the difference between horns and "normal" speakers might be that the horns don't benefit as much from a high damping factor, it doesn't change the fact that a series resistor will spoil the damping factor.
Old 17th January 2013, 06:02 PM   #6040
But the question is how much influence it has. As I stated before horn speakers are acoustical damped devices, they do not need any electrical dampening by the amplifier. So there is nothing to spoil with a series resistor. It is a utterly wrong assumption that the damping factor of an amp has an influence on sound quality in horn speakers!
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
