hypex ncore - Page 601 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 16th January 2013, 04:04 PM   #6001
Julf is offline Julf  Europe
Originally Posted by akasha View Post
and some of us cant set us self free of that fact
"set your mind free" - I thought we left that back in the 60's
music reproduction is NOT only about lowest distortion
I don't think anyone has claimed it is...
OK, this is becoming Yet Another Subjectivist vs Objectivist debate, so I will leave it at that.
Old 16th January 2013, 04:15 PM   #6002
akasha is offline akasha  Denmark
Originally Posted by pos View Post
Removing R141 will put more "effort" on the preamplifier in front of it (~13dB more to output for the same level with the same low sensitivity loudspeakers). Maybe that is where the difference you heard comes from?
thats what I write, yes
but it does not explain all, as 2 preamps that should have sufficient power sounded dull as well
Old 16th January 2013, 05:17 PM   #6003
Originally Posted by StigErik View Post
I don't have a pre. DAC's are connected directly to the Ncore's. That's why I needed to reduce the gain.
Erik, I just ordered 2 days ago a second dac to try a "no pre" system
(=> 2 way active crossover)
I plan to use a DSP with volume control, maybe a nanoDIGI.
In your case, how do you control volume ?
Concerning the sound quality with or without R141, I did not notice any change with a passive attenuator (TVC). (2 day ABX test, the time to fix my Ncore... )
Old 16th January 2013, 05:27 PM   #6004
3lviz is offline 3lviz  Finland
I got two sets of ncore, one with and one without r141. I haven't noticed any different in sound between them (other than the latter was quieter). The problem must have been somewhere else than absence of r141 if there was a huge difference in sq.
I could take "i could hear a small difference", but "it was barely HiFi"...come on .
Old 16th January 2013, 05:37 PM   #6005
StigErik's Avatar
In this:
(digital volume control, before the DAC's)
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 16th January 2013, 06:03 PM   #6006
ok, 2 DACS ?
I use a Touch, but I need another solution, I want to use the system to watch movies also ...
Old 16th January 2013, 06:48 PM   #6007
StigErik's Avatar
I run the Squeezebox output through a digital XO, ending up from an 8-channel DAC. Currently I use only six channels.
Old 16th January 2013, 07:54 PM   #6008
ok, 2 DACS ?
This and its optical out has been serving my movie (and music) needs for sometime already:
http:// http://www.origenae.co.kr/en/htpc_s10v.htm
Simply cannot be beaten in versatility...
BR,
Timo
Old 16th January 2013, 09:56 PM   #6009
fas42 is offline fas42  Australia
Banned
The dilemma of low distortion equipment, or systems, is that you can then listen "deeper" into the sound without effort: mediocre sound smears everything with a relatively uniform patina, which may be pleasant, or unpleasant, and one tends to listen to the outside surface of the musical happenings. So, if you can listen further into the mix then your ear adjusts, and realises that something that didn't register before is very clear, and in fact is "wrong", could be improved. Hence the journey continues ...
Frank
Old 17th January 2013, 12:35 AM   #6010
Send a message via Yahoo to mr_push_pull
your system is not resolving.
back to square one!
we all love a good ol' stereotype until it's against us
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
