| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#5911 |
As promised here are some pictures of my NC400īs in their acrylic housing. These cases were originally build for an xover. Thatīs why some holes are not properly drilled for the actual use. But it was the best way for me to bring my NCores to life and use them until I get the aluminium cases to build real big mono blocks. I think the NCores deserve that additional investment.
And, yes, the stands suit for my ARC Monos. They are a bit oversized for the actual cases. Waiting for the new cases... |
#5912 |
Hello,
I get my new NCore and SMPS600 on thuesday. I am very happy with the sound. As I need to lower the gain with my 100dB speakers, I removed R141 this morning. One of the NC400 has now a problem ![]() When it powers on, the red leds light on as expected and then I have a big "ploc" on the speaker, and another one a few seconds after (I unplugged the power to avoid damage on my speaker ...). I tried it on my test speakers and it was the same ... the boomer moved a lot a very short time... The other NC400 works as expected, with lower gain. I dont know what to do... I have sent an email to hypex support, I hope to get an answer next week. |
#5913 | |
#5914 | |
A man should look for what is, and not for what he thinks should be. -Albert Einstein |
#5915 |
I experienced exactly the same with one of my Ncores after removing R141. I cleaned the board for all solder remains with a toothbrush and the problem was solved.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#5916 | |
Do you mean to say that the NC400 with 6" speaker wire outperforms the NC1200 with the longer speaker wire? I thought you were indicating in an earlier post that the NC1200 sounded better even when using longer speaker wire? Appreciate if you could clarify - thanks! |
#5917 | |
I was thinking the same, but the toothbrush wash did not help. One of the "pad" of R141 came with the resistor. I dont know if that can be the problem. I will bring the ncore at work tomorrow, we have all the magnifiing glass we could dream of ... |
#5918 |
I think you have a serious problem..... It is a multilayer board!
#5919 | |
I had the same thing happen to one of my 8 nCores as a result of rushing the desoldering job... |
#5920 |
Why do people always want to change the gain? If you have high sensitive speakers, put a attenuater between your ncore and preamp!
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
