hypex ncore - Page 589 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th January 2013, 04:05 AM   #5881
Originally Posted by barrows View Post
Is a well known fact that the two available nC1200 amplifiers (Merrill and Atsah) both use the stock input buffers on the nC1200 modules.
It will be more interesting when someone decides to pair the nC1200 modules with a different input buffer, as is the case with some of the regular Hypex amp modules.
Thanks barrows,
I see.
So the joke is the fact that the expensive commercial offerings use Bruno´s OP amp buffer whereas lucky DIY´ers can acquire the less expensive nc400 with Bruno´s discrete buffer -which the DIY´ers in fact called for themselves, and which reportedly sounds worse than the nc1200 which instead measures worse.
....And then we are to learn that none of the "snake oil" stuff that the commercial vendors do can "in fact" cause the preferred difference in performance to the mere nc400???
- I guess that "joke" isn´t that funny around here
Total inconsistency
Old 9th January 2013, 05:16 AM   #5882
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Originally Posted by cjf View Post
Hello UA100k,
Thanks for your response and the added pictures. I can see that the back of the Merrill unit does indeed look much better layed out with higher quality speaker binding posts and XLR connection Input then the other offerings I have seen thus far.
I would still love to see some pics of guts of the unit but if that request would compromise any secrets used in its creation then I understand the hesitance to show that layout in all its glory. At least the product description mentions that some effort and material was expended to better isolate the various components from each other during the design/build phase of the amp.
Based solely on what I have seen in print and pictures and read from current owners, I give the Merrill Veritas a "Gold Star" over the competition at the moment; even if the IEC connector doesn't look to made of gold taken straight from an Egyptian Pharaohs lost stash.
Let me guess..... A piece of alu with two boxes milled inside, the smps behinde the IEC and the nc1200 on the other side? Plain rocket science!
And they did not bother to make a proper standby psu for the trigger input, it only mutes the nc1200 and does not put the smps in standby.
Old 9th January 2013, 05:27 AM   #5883
Regnad is offline Regnad  United States
I have both amps and would enjoy a visit if someone would like to listen to each...
The NC1200 has more power, right? With low-efficiency speakers couldn't that contribute to a difference (improvement)?
I did think that the NC400 sounded better at the speakers with 6" speaker wires.
Old 9th January 2013, 05:33 AM   #5884
ds23man's Avatar
With low-efficiency speakers the amp with more power will always have the advantage. But can you tell me if they sound different with normal eff. speakers?????
Old 9th January 2013, 05:37 AM   #5885
ro9397 is offline ro9397  United States
My speaker array comprises two identical monitors per channel, each monitor is 8 Ohm nominal/5.3 Ohm minimum. I have the unique ability to load my Ncore with two otherwise identical loads, 10.6 Ohm minimum or 2.65 Ohm minimum.
With 9AWG Ncore was more pure and transparent into 10.6 vs. 2.65 Ohms. With 4AWG parallel with separate 30AWG Ncore results inverted.
I suspect a certain percentage of persons not necessarily enthralled with Ncore heard it with less than ideal speaker cable.
James
"Television is the poor man's whiskey." Russel Baker
Old 9th January 2013, 06:07 AM   #5886
How many speakers with 87.5 dB sensitivity (mine) can handle more than the 500W my NC400 make into the 2.65 minimum impedance load?
My dual Dynaudio Esotec 17cm and dual Esotec D260 appear to thermally compress before NC400 runs out of steam, even in .35cf sealed enclosures and active HP crossed 2nd order @ 80 Hz! And that's three Trinaural channels, not two/stereo, in only 3k cf with moderate absorption/diffusion. (Admittedly 1st order @ 2.2 kHz, but tweeter is padded down 3-4 dB.)
James
Old 9th January 2013, 06:15 AM   #5887
Originally Posted by Juhleren View Post
Thanks barrows,
I see.
Total inconsistency
Man, that is depressing.
The DIY community screamed for discreet for NC400, which costs more, sounds worse, and measures better than the NC1200 op-amp which costs less, sounds better, and measures worse?
Is it not true that op-amps have multiples higher tolerance? What made the op-amp measure worse?
Man we are stupid! Or Bruno was for accommodating us!
Tell me you're kidding, puhleeeeeze!
James
Old 9th January 2013, 06:50 AM   #5888
ds23man's Avatar
Who said the discrete input sounds worse????
How much NC1200 amps are there on the market today??
Old 9th January 2013, 08:19 AM   #5889
Abraxas336's Avatar
It’s not Hypex' fault but the quality of this thread went from average to unpalatable over the last weeks. Yackety-yak and hearsay promoted to facts, fan boys and ignoramuses with philosophies bashing what they consider dissidents and hardly any actual information. It’s annoying and I'll unsubscribe now.
Gruenschnabel
Old 9th January 2013, 10:53 AM   #5890
Bye, Bye!
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
