| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#5861 | |
#5862 |
well, I don't know. Regnad confirmed a not exactly minor sonic difference. who knows? I certainly don't think that "high end cables" (what exactly does that mean and what is the measure of highend-ness?) can be responsible of "huge" differences (again, direct experience proved that one man's huge is another's not discernible) but vibration control and good shielding, maybe.
we all love a good ol' stereotype until it's against us |
#5863 | |
If it is a tube amp, I am in....... |
#5864 | |
Due to my work, I am able to access many professional graded equipments (EMI treatment, shielding, vibration control etc) designed for lab R&D, hospital, and military. These stuffs are not meant for used on audio equipments, but they do work very well; it is just that the prices are not justified for the audio listening purpose. Have you tried to add a power regenerator before the nCore VS plugged it in directly to a wall outlet? or a Shunt regulated power supply on nCore? i know that defeats the purpose for Class D, but you will be amazed by the improvements. |
#5865 |
well, I said maybe. worth considering, definitely. maybe someone attempted to measure it?
#5866 |
Still waiting for someone with wires made with copper ore dug buy Vestal Virgins!
Maybe this will sound the best! |
#5867 | |
this definitely doesn't mean that we need to believe something just because X said so but if there's enough empirical data to deem a phenomenon worth investigating, why not?
#5868 | |
But vibrations in a solid state amp I don't believe in as a former sound engineer. Done a lot of testing with high power rigs ( 100kw and up), we had to change the source ( cd player) to Dat because the sound level made it skip. Did not notice any problem with the rest of the gear...... Last edited by ds23man; 8th January 2013 at 06:15 PM. |
#5869 |
I'm just sharing my findings so far. I hope they can be useful to someone else on the forum.
Regarding the vibration control, I did some testings, but most of the so called hifi solutions are for fun only. If you are serious, give this a try: Vibration Isolation Isolators, Tables, Platforms & Systems | Minusk Technology Even the cheap models will work very well. Tested on solid amps before, and it worked. However, it made more differences on the DAC than on the Amps - I still cannot figure out the reason behind it. Again, all the equipments/technologies that I tested on my nCore monoblocks are not commonly available to the public, so my findings might be irrelevant. |
#5870 | |
Solid state electronic is very sensitive to vibrations and need special cones/feets build from solid unoptainium. Even if you cannot record any noise from its output, while trying to destroy-it with a hammer. |
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
