hypex ncore - Page 584 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 2nd January 2013, 01:29 AM   #5831
robbbby is offline robbbby  Canada
Originally Posted by ds23man View Post
I decided to run a groupbuy for the standby pcb I made. I will order a batch of 50 pcb's at Itead. Prices and detail will be published later on in a seperate topic!
Can you update this thread as well when they're ready. I only subscribe to this thread and don't browse the rest of the forum.
Old 2nd January 2013, 03:51 AM   #5832
Regnad is offline Regnad  United States
Originally Posted by ajst2duk View Post
Very interested in the comparison between the Ncores and the Veritas amps - were the Veritas noteably different to the Ncores and with which specific aspects ??
After assembling the NC400s I wanted to hear what more power into the 81db MBLs would do and the Veritas were the only reasonable route to those NC1200 modules. I would have been happy with just more power but, to me, low end control, space and detail were all improved. There also is the Veritas milled block chassis, shielding, high quality components, wire and assembly. My Ncores were a very basic build.
The combination of that high SN ratio and low output impedance must have something to do with it. Add small size and efficiency and wow.
System is so good now, using Bryston BDP-1 > PS Audio PWD > Musical Fidelity M6PRE > DPSpeaker DualCore all balanced into the amps. The DSPeaker really smoothed things out below 100 hz.
I had the NC400 amps right at the speakers with 6 inch speaker wires and though it sounded better, maybe because of the low output impedance relative to the speaker wire resistance. Not really practical with the Veritas, though.
Old 2nd January 2013, 09:07 AM   #5833
Julf is offline Julf  Europe
Just to make sure I understand - while the latter part of your post seems to say the nC400 amps sounded better than the Veritas (possibly because of the shorter speaker cables), I am not sure about the first part. Are you saying the Veritas sounded better than the nCores, or are you saying that both the nCores and the Veritas sounded better than your previous systems?
Old 2nd January 2013, 04:50 PM   #5834
Sorry, short speaker cables did improve the NC400s which were already better than the 2 amps I had previously used (CJ 275M and Parasound JC-1).
The Veritas (with the NC1200 modules) was quite a bit better still. It was at this point I did not need the subs, which was great because I got rid of the crossover and delay needs. Now use the subs just for movies.
To clarify though, the NC400 and Veritas (NC1200) amps are both Ncore-based.
Old 2nd January 2013, 05:17 PM   #5835
Waiting for final info.
Interested for 2
Old 2nd January 2013, 05:41 PM   #5836
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Interested for 2
Details will be there after I receive this batch. Because it is shipped from China into Europe, it is always a surprice with taxes and import duties.
Old 6th January 2013, 07:01 AM   #5837
out of curiosity, are there any builds done with 12v trigger to power things up?
Old 6th January 2013, 10:44 AM   #5838
Yes, I have. I power up with trigger connected to a softstart. The softstart is used in an alternative way. 5 channel nCore.
Old 6th January 2013, 07:28 PM   #5839
Ordered my nCores and PS yesterday. So please count me in for two of your marvellous standby prints. Do you attach an advice how to connect them to the PS or is this foolproof anyway? If not I will be the fool to proof...
Old 6th January 2013, 07:55 PM   #5840
cjf is offline cjf  United States
Does anyone have any pics of the guts and back of chassis of the Merrill Audio Veritas amp they could share? I'm not seeing this on their website for some reason. 9 pictures of the front/sides but nothing showing the back...
I am curious to see if the Veritas is built any better on the inside then the Acoustic Imagery Atsah that was reviewed at 6moons. After seeing the innards of the Atsah I'm having a hard time justifying its $9K /pr asking price.
As also mentioned in the 6moons review of the Atsah I too would have expected to see some attempt at component isolation at this price point as well as a better layout of the binding posts.
Maybe I'm asking for too much here but since they already went thru the trouble of using a milled aluminum chassis how much more effort would it have been to give each board its own separate area for better isolation, shielding and vibration immunity? Would this make any difference in SQ, who knows but at least the cost would be better justified IMO.
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
