| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#5711 |
If the hiss is generated by the DAC output circuit, and if any volume margin available, providing some attenuation in input will increase the signal/noise ratio, thus reduce the hiss by the ratio of attenuation. 2 resistances, not a big deal.
#5712 | |
http://www.jensen-transformers.com/datashts/dm2xx.pdf
Music is art - Audio is psychoacoustics & engineering |
#5713 |
Sure - but if the problem is some ground loop or HF oscillation interaction with the DAC, as opposed to a pure DAC problem, we don't just want to attenuate the problem, we want to get rid of it.
#5714 | |
60% the price of the amp, for something you cant assure it will solve the issue ? Very constructive, indeed. |
#5715 |
#5716 |
You're quite right Julf, just wanted to reply to imho a to broad generalization about audio x formers.
#5717 |
I agree, Mark - audio transformers can be surprisingly good, and even their error modes aren't too bad (limited "ultrasonic" range, soft clipping when overdriven).
#5718 |
Some nCore users have reported excellent improvements in sound quality when coupling a DAC to the nCore via a tranformer of some type. Output transformers in the DAC, TVCs, and input transformers in the amp have been reported to result in sound quality improvements.
I noted that one DAC I tried with the nCore produced a course grainy noise floor (still only audible with an inch from tweeter), and have come to suspect that the nCore is sensitive to RF on its input (as are many class D amplifiers). So, as Julf is pointing out, there may be additional benefits to reducing the gain of the Mytek DAC via a transformer which would justify the high price. Also, going amp direct, using a transformer to step down the voltage a little increases the current drive vs using a resistor based solution, and I find having higher current availability is a good thing when driving amplifiers directly as well. |
#5719 |
sounds like what my DAC was outputting. kind of like a modulated buzzing noise.
we all love a good ol' stereotype until it's against us |
#5720 |
Well. it is a little like tube amps (because the use audio transformers ? ;-). Quite a natural sound, kill the magic of very fast systems.
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
