hypex ncore - Page 566 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 26th November 2012, 11:02 PM   #5651
jtwrace is offline jtwrace  United States
jtwrace's Avatar
Why is the input cabling so long and coiled?
"Science is not a democracy"- Earl Geddes, Ph.D.
Old 26th November 2012, 11:05 PM   #5652
robbbby is offline robbbby  Canada
Good question, I just figured that because they're shielded there would be no harm in leaving them long if for some reason I ever had to move them to a different case or something.
Old 26th November 2012, 11:09 PM   #5653
jtwrace's Avatar
Gotcha.
See mine here Show Us Your Core-NCore!
Old 26th November 2012, 11:22 PM   #5654
Banned
what is the best way to "shield the cables? Just wrap them in aluminum foil? Does the shield need to be grounded?
Yes to all. For a try, just wrap aluminum foil and wrap a coper wire around to make a good contact to ground. Then, if your problem is solved, you can try to remove your adds one by one to see witch of them makes the trick.
Here, a perfect build from a very talented audio designer. Schield between SMPS and amp, of course: Class D Amp Photo Gallery
Old 26th November 2012, 11:48 PM   #5655
It looks like he just has a shield between amp and smps, nothing shielding the wiring, yet the speaker wires and smps wires are very close to each other. Guess i'll just try something between amp and smps.
jtw, gorgeous, I remember seeing you pictures a few months back.
Old 27th November 2012, 12:37 AM   #5656
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
robbbby, whatever they said, try to put a shield between PSU and amp, and shield PSU cables too.
Easy to do just Dirty, for a test, and see if any change.
This really is not the cause of what you are observing. My amps.(and I suspect others) have a far poorer layout than yours, according to Christophe's suggestions, without the effects you are reporting. My amp module is above the smps with approx a 90mm air gap between them with the component sides facing each other. (Don't tell anyone, but I've got NO additional screening)
Assuming you've got a female xlr on your amps, simply poke a piece of copper wire between the + and - terminals and then see how it behaves - no noise/pop means the cause is something upstream and nothing to do with your layout or modules.
With regards your internal amp layout and cable twisting, it looks pretty good apart from the coiled input cable - I've also left my input cable full length (but don't think this is right and intend to change it - it was a big element of laziness when I assembled the amps). However, if you're going to leave it full length, re-lay it without the loops; instead 'snake' it backwards and forwards in a big 's' so there are no loops.
Old 27th November 2012, 12:45 AM   #5657
Chris, I did the test shorting the hot/cold on the input, my results were a few posts back, ended up with dead silence on my speakers and just a faint pop when cycling the amps. When you say the cause is something upstream what are you referring to? When doing the test there is nothing hooked up to the input, only thing plugged into the amps is AC power and speakers.
I also tried the shielding test and it didn't improve anything. Shielded the cables between amp/smps and also made a nice shield to put between amp and smps and made sure both were well grounded. Same little pops on power cycle and lots of static/white noise.
Old 27th November 2012, 01:03 AM   #5658
Default robbbby...
I have noted that the nCore amps may be sensitive to RF on their inputs. Example: the last pair of nCore I had here (a mono block pair built for a friend) were perfectly laid out and wired. With open inputs (not shorted) thye exhibited an extremely low noise floor, with a very smooth, soft, evenly textured hiss at the tweeter, only audible when the room was very, very quite on a calm night, with everything else in the home powered down.
When one DAC I have here was connected and powered up, the noise floor of the nCore became highly static-y, although the absolute level of the noise was still extremely low in level as to be only audible with the ear within an inch or so of the center of the tweeter. Another DAC connected to the nCores exhibited no such rough noise floor. My conclusion is that the nCore amps are sensitive to RF on their inputs, and some DACs are going to have more RF on their output than others. This worries me enough (as this energy may fold back into the music signal) that I am considering transformer coupling my DAC to the nCores.
It may be that your Mytek has enough RF on its output to create this rough noise floor.
Your POP at start up is due to the DC on the Mytek's output, and unrelated to what I ma describing here.
Old 27th November 2012, 01:08 AM   #5659
Banned
Just because your cables are very close, even touching not his ones. My suggestion was just a try that cost nothing to figure out.
Old 27th November 2012, 01:14 AM   #5660
Banned
The problem comes from your preamp, if you have no problem when input shorted. Try change the phases of your preamp and amp power cords, (various combinations, with nothing else connected from your preamp) change sources to figure-out etc...
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
