| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#5491 |
There is nothing to argue, in the correct way to design electronic. A good knowledge of components and the way they behave.
Like resistances noise or serial inductances, cap serial inductances, cap serial resistances, caps distortions, parasitic caps and inductances of wires. A good knowledge of schematics, and the way they behave. Accurate calculations according to the scientific rules. Then you build a prototype, using the accurate components for your needs and measure and tune. Then you begin to listen to carefully, and try to improve things with different parts or so... If you find any remaining not explained problem, any real improvement you can hear and cannot explain, time to try to understand what's happens, why, and correlate with theory. It is that way, hearing different sound from different caps, that some ones had begun to measure precisely different caps, and found behaviors that everybody is supposed to now, nowadays. |
#5492 |
What AP2 is talking about is very real. What sound is sounding like when you are getting drunk is temporal resolution loss :-)
#5493 |
is choosing a less facetious title...
are you replying to me or Mr Push Pull?
if me, I think you missed my point, but i'll just agree anyway because none of that actually clashes with my point. where the problem is, is reconciling that with the many and varied experiences of each and every sound and sound system, also the fact that measurements are interpreted subjectively too =) not often mentioned that one, we tend to accept our visual reality much more factually. Last edited by qusp; 18th November 2012 at 10:29 PM. |
#5494 |
About the fully regulated smps comment. I am wondering how feasible it would be to design a high current fully regulated power supply. Usually regulators have around 0.5-1.5A current capacity. You can have several for higher current capacity, tho.
However, wouldn't it be smarter, instead of designing a general purpose high current power supply, design the module and the power supply so that they work together as good as possible (like in case of smps600 and nCore) to make things easier for the future, if for instance higher current levels are needed. And then regulate things in the module side if/when needed. That would be designing a platform folks, not just making one product work. I can appreciate that. Last edited by 3lviz; 18th November 2012 at 10:53 PM. |
#5495 |
I've had both for ages but I'm still waiting on a friend to buy another pair of NC400s so that we can have a useful, side-by-side, comparison of the two setups.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones |
#5496 |
Not a real problem, both for linear or switched ones. Just paralleling parts if not enough current in one power switching/balast device.
#5497 | |
Good point about our visual reality - visual interpretation of measurements is a very powerful practice when constructing factuality -also factuality about sound
#5498 | |
Frank |
#5499 | |
As it is a closed loop, the internal impedance is achieved by feedback. After all, a PSU is just a classical amplifier, witch amplify in current a static voltage reference, can be low high power low Z. For Ballast, the output caps are here to minimize impedance. It is just a cleaned linear PSU. Last edited by Esperado; 19th November 2012 at 05:11 AM. |
#5500 | |
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
