Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 4th November 2012, 07:10 PM   #5331
Telstar is offline Telstar  Italy
Originally Posted by Julf View Post
Depends on how you define "clean". Is "clean" response within +-3 dB? Or an absolute upper limit at least 2 * higher? Or something else?
-3dB at 30khz is fine, including also the eventual amplifier rolloff.
With clean i meant two things:
*perfect 15khz squarewave
*no dithering/aliasing artifacts up to 30khz (better 50)
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 4th November 2012, 07:12 PM   #5332
Send a message via Yahoo to mr_push_pull
anytime the HF debate comes up, I can't help but remember that most of the audio catalog available today is in a format that can't hold any audio info past 22kHz. last time I checked, oversampling can't "reinvent" the information that has been low-pass filtered at the recording side in order prevent aliasing.
I've read many positive reports about super-tweeters. funnily, the latest I can remember came from a guy that used RedBook. talk about credibility...
we all love a good ol' stereotype until it's against us
Old 4th November 2012, 07:14 PM   #5333
StigErik's Avatar
-3 dB at 30kHz will not give you "perfect" 15kHz squarewave.... not at all. You'll need bandwidth far into the MHz range for that.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 4th November 2012, 07:17 PM   #5334
Julf is offline Julf  Europe
Why? Nobody listens to 15 kHz square waves.
Again why? if you can't hear those artifacts, all you need to do is make sure they don't cause any intermodulation or distortion.
Old 4th November 2012, 07:20 PM   #5335
Maybe some of us only listen to quadrophonic vinyl from the 70's
Old 4th November 2012, 07:21 PM   #5336
I guess he meant perfect as in as much as the scope's display allows, given certain timebase
Old 4th November 2012, 07:22 PM   #5337
Well, to be precise, to get perfect square waves you need unlimited bandwidth. Hmm... Maybe there is a need for terahertz amps...
Old 4th November 2012, 07:24 PM   #5338
"These claims are being made by people with cheap scopes with limited resolution"
Old 4th November 2012, 07:26 PM   #5339
quite possible.
personally I have such varied musical tastes that I can't imagine myself in that position. music can deliver such a wide range of emotions that I find sticking to certain genres/time windows very restrictive in that regard. but I digress.
well...
Old 4th November 2012, 07:39 PM   #5340
I raise you a tuvan throat singer accompanied by 3 mustaphas 3 and one fake cuban conjunto doing kraftwerk covers...
Hypex problem, who can help Hansms Class D 8 10th March 2011 08:18 PM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Copyright ©1999-2013 diyAudio
