hypex ncore - Page 524 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 18th October 2012, 01:02 PM   #5231
tony399 is offline tony399  United Kingdom
Old 18th October 2012, 01:04 PM   #5232
Originally Posted by mr_push_pull View Post
I thought there is some aux out that always delivers power.
From the SMPS600? I hoped so too but the data sheet shows that once in standby both main and auxiliary output voltages will drop gradually
Old 18th October 2012, 01:12 PM   #5233
Send a message via Yahoo to mr_push_pull
then I can't think of any quick way. the quickest, dirties and cheapest way to get the collector voltage would be to use the SMSP from a phone charger (small, galvanic isolation).
we all love a good ol' stereotype until it's against us
Old 18th October 2012, 01:19 PM   #5234
Thanks for the tip.
Do you think there would be any harm in just using hard switching of the mains AC with relays? ie. nAMPON tied to ground, and leaving the SMPS's standby feature unused.
Old 18th October 2012, 01:31 PM   #5235
I'm not the authority here but... I thought you wanted to use the control input because your source has a control output. if you're willing to give it up I'd say there wouldn't be any problem. most people here don't use it anyway.
Old 18th October 2012, 01:39 PM   #5236
Call me old school but I don't like turning equiment on and off - that always seems to be what causes it to blow up! My current solid state amps and other Class D amps are left constantly on. I'm happy to do the same with the ncore's, but since I'm having to re-build everything anyway, I thought I might as well include some way of turning them on and off with the standby feature of the source.
My idea is to use the 12v output of the source to trigger relays that connect AC live to the SMPS600. It would just have been nice to be able to use the standby feature but I guess Bruno hasn't allowed for standard trigger switching.
Old 18th October 2012, 01:43 PM   #5237
Julf is offline Julf  Europe
It wouldn't add much complexity to have the relay switch a very simple low voltage supply instead of live AC - the benefit being a) soft start/shutdown, b) not having to switch AC, and c) not having to route the SMPS600 supply through limited-capacity relay contacts. Oh, and d) being able to use a much smaller relay.
Old 18th October 2012, 01:48 PM   #5238
Hmm very true... So thinking out loud... The source triggers a very small 12v relay that connects a very small mains transformer (constantly connected to mains) to a dc rectifier that's connected to the standby pin of the SMPS. Yes that does sound like a much better idea
Old 18th October 2012, 01:50 PM   #5239
If the psu is in standby there should be somewhere to tap off a permanent voltage output, this would be a lot simpler than all the extra circuitry, I would suggest asking Hypex for help on this.
Old 18th October 2012, 02:04 PM   #5240
ds23man is offline ds23man  Netherlands
ds23man's Avatar
I made a nice standby psu for the hypex smps/ncore/ucd.
It can be used with a latching or non latching switch ( low voltage) and can also be used with an external 12v trigger. I will post more details later.
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
