hypex ncore - Page 523 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 17th October 2012, 08:09 AM   #5221
Originally Posted by Julf View Post
I agree - that's why I was surprised to hear a claim it could actually cause distortion, but then a lot of people do claim effects of turbulence in bass reflex vents.
And indeed there are; air velocity in ports reaches highway speeds.
Noah
Old 17th October 2012, 11:33 AM   #5222
Default Quick questions
I'm just designing the layout and wiring for my ncores.
The ncores and smps will me mounted on the rear of the speakers, basically on a metal stand-off plate, probably enclosed with perforated sheet.
There will be a distance of about 8 inches between the ncore's output and my speaker's tri-wire terminals. It doesn't look like I'll be able to fit more than 2 wires onto each ncore output terminal, ie. biwire. So I guess I could either use much thinner speaker cable, or biwire into triwire at the binding posts, using one pair of connections for the woofer and one pair shared across the mid and tweeter. Any suggestions guys?
Also I wanted to ask if there would be any improvement by individually shielding (enclosing with perforated sheet) the ncore and the smps from each other, since it doesn't really make any difference to the build.
Old 17th October 2012, 07:59 PM   #5223
igy137 is offline igy137  Switzerland
Hi All,
I'm in the work of building active loudspeakers with 3 ncores per speakers, and I'd like to minimize the place used by the power supplies and ncore modules.
I'll have two SMPS600 powering 3 modules: 1 ps for the bass, 1 ps for mid/tweeter.
I was planning to use 5-6 cm spacers and stack the ncores on the top of each other, and doing the same with the power supplies.
Is this enough or do I need to keep more distance between them to keep the best performance?
Also, is it ok to keep the ncores very close to the power supplies?
Thanks,
igy
Old 17th October 2012, 08:04 PM   #5224
Julf is offline Julf  Europe
I am not sure it is a good idea. It does place the inductors close and in alignment with each other, so there might be interference.
Old 17th October 2012, 08:07 PM   #5225
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
Hi All,
Thanks,
igy
Bruno & Jan Peter seem to be more than happy with this
Control how your interconnecting wires are routed and keep them twisted
Old 18th October 2012, 11:21 AM   #5226
StigErik's Avatar
No problem at all.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 18th October 2012, 11:33 AM   #5227
Hi again...
One other question as well as the above, is there any way to invert the SMPS's standby feature (pin 1)? My source has a 12v trigger output that goes live when switched on, pretty standard for hifi. But the SMPS goes into standby when pin 1 is live. Not good!
I can only think to use 12v mains relays that switch the mains live feed to the SMPS.
Would really appreciate some other suggestions
Old 18th October 2012, 12:57 PM   #5228
Send a message via Yahoo to mr_push_pull
Hi again...
a transistor?
we all love a good ol' stereotype until it's against us
Old 18th October 2012, 12:58 PM   #5229
Originally Posted by mr_push_pull View Post
a transistor?
Wouldn't I then need another 12v source to keep the SMPS on standby?
Old 18th October 2012, 01:02 PM   #5230
I thought there is some aux out that always delivers power.
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
