| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#4661 | |
#4662 |
I would recommend you to put some metal behind the wooden front and rear panels to increase the shielding properties.
Live sounds better than HiFi. |
#4663 |
Chassis shielding is possibly a detriment, imo. Aluminum reacts with magnetic fields.
#4664 |
Especially when it is hat shaped and placed on one's head....
#4665 |
I believe the wood pieces are the sides of the chassis, nothing would be attached to the wood. I have been reading to try and gain a general electronics understanding so I wont kill myself or burn down the house. it is my understanding that copper & aluminum provide electrostatic shielding whereas steel and Mu Metal provide both electrostatic & magnetic shielding.
#4666 | |
#4667 |
Bruno says most of the EMI is carried on the cabling anyway. A shield is therefore probably most effective in shielding the amp from EMI radiation, but likely impacts the amp's operation to some extent, probably small.
#4668 |
Aluminium will act as a magnetic shield for AC magnetic currents. It will do nothing to DC magnetic currents. A ferrite will reduce the EMI from leaking via the speaker cable. Some equipment is sensitive to EMI at certain frequencies, and the EMI from a class D amp is both pretty broad band and quite load dependent.
#4669 |
For shielding to be effective it's got to be really close to the source. Chassis make lousy shields because anything you might be trying to shield against has already coupled into the wiring inside the chassis. If you want to use the chassis as a shield you need to have feed-through filters on every piece of wire. But that's something you'd only do if there was a problem to begin with... The NC400 is pretty quiet so I'd just pick the chassis on aesthetical grounds.
@juhleren if I follow your reasoning you're proposing that placing a large inductance across the speaker somehow affects the signal in a good way? Before discounting the resistor hypothesis it's worth an experiment to add a small resistance in series with the amp and hear what it does.
There's a time for everything, and this is not it. |
#4670 | ||
DC magnetic currents? And in what way will a static magnetic field influence *anything* apart from a compass needle? (OK, it might pre-bias some transformers, but is that really a factor to consider?)
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
