hypex ncore - Page 454 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 22nd June 2012, 12:22 AM   #4531
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
Abraxas
Twist the psu cables
Twist the speaker cables and take them from the same side of each terminal
This is mentioned on the data sheet (and earlier in the mega thread)
Can't see what you've done with your input leads - what are the terminals of the RCA connected to?
The orientation of the right hand amp is better than the left as the input cable avoids the psu wiring
Old 22nd June 2012, 07:24 AM   #4532
In terms of noise this is going to be the crucial bit.
There's a time for everything, and this is not it.
Old 22nd June 2012, 07:40 AM   #4533
serengetiplains's Avatar
Bruno or JP, what is the nominal DCV of the driver voltage supply on the SMPS600?
Old 22nd June 2012, 08:15 AM   #4534
20V - ish (not regulated, hence dependent on load and line conditions). The NC400 internally regulates this to 15V.
Old 22nd June 2012, 08:21 AM   #4535
Abraxas336's Avatar
Alan, Chris, Bruno:
Re inputs - input pins 2,3,4 go to the ground of the RCA connector, basically like in figure 4 of the data sheet without case. Input cables are not fixed in any way - if connected they are placed away from the psu wiring.
I used RCA to be able to connect sources directly and skip preamplification. Since there is no additional "ground" it should be ok?
Re twisting - I know they are supposed to be twisted, but this is the impatient setup . I agree however that before mentioning noise that should have been done. Will correct and report back.
Best Regards
Sven
Gruenschnabel
Old 22nd June 2012, 05:50 PM   #4536
going directly from source is quite lovely, however its still preferable to use a balanced input connection extended to the output of the source, even if the source is unbalanced (such as your setup).
This retains the inherent noise rejection properties of the balanced input in the amp. So that means an XLR on the amp end and phono on the source. See Bruno's notes on building it.
The twisting isn't as important as moving the output wire away from the inductor.
Still hope to get the answer to the question: is there any noise with the input connectors disconnected?
Alan
Old 22nd June 2012, 05:57 PM   #4537
Curious, what is the dropout voltage for this regulator?
Alan
Old 23rd June 2012, 01:17 AM   #4538
I apologize in adance for the novice questions. I have searched this thread for my answers and I think I understand the input cable connections. I am about to solder my Mogami cable to the XLR connectors, but before I screw up, could someone please help me make sure I am doing this right. I plan on using the "Preferred" connections for fully balanced use. Thanks.
1. I have no ground connected to my IEC, correct?
2. Is the "Nampon" wire the small black wire attached to the Mogami cable?
3. Does this wire connect to the chassis?
4. Is the shield wire of the Mogami cable also connected to the chassis?
5. It appears that the XLR connector shown as "1Q" is also connected to the chassis.
If I am correct, the XLR "1Q", Nampon wire and the Mogami shield are all connected to the chassis with no ground connection to the IEC?
Old 23rd June 2012, 07:26 AM   #4539
Julf is online now Julf  Europe
Yes to all of those, but you might want to keep the chassis connections short and close to each other.
Old 23rd June 2012, 08:32 AM   #4540
Will do Julf.
Thanks for the reply.
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
