hypex ncore - Page 453 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 21st June 2012, 04:21 PM   #4521
Originally Posted by chlorofille View Post
What speakers are you using?
They started life as Hales Transcendence 8 loudspeakers but by now only the woofers are still stock. More $$$ has gone into mods/upgraded parts then what they originally retailed for ($10Kish).
Old 21st June 2012, 06:13 PM   #4522
Abraxas336's Avatar
Behold - the mighty breadboard!
https://dl.dropbox.com/u/14228451/IMG_4855.jpg
https://dl.dropbox.com/u/14228451/IMG_4856.jpg
https://dl.dropbox.com/u/14228451/IMG_4857.jpg
I would like to declare that despite these pictures - given enough time - I am able to build/assemble a decent piece of equipment.
Sven
Gruenschnabel
Old 21st June 2012, 06:53 PM   #4523
hifial is offline hifial  United States
Sven, your speaker wire and spades to the Ncore amp is not done right . the spades should face the same way and I believe the wires should be twisted. Someone with more knowledge then me will confirm that and if there is anything else that needs to be addressed.
Old 21st June 2012, 07:02 PM   #4524
1) take the speaker leads from the same side (toward the edge), not opposite, and away from the inductor, then twist together, doesn't need to be much twist.
2) put xlr's on the input and use the amp in balanced mode. this can make a huge difference in noise induction into the amp. you will need a rca to xlr cable preferably or an adapter. see Bruno's papers for proper construction.
3) Under normal construction situations, the chassis ground from the SMPS and the Ncore would both be attached to the chassis, you could simulate that with a wire between the two. Not sure if that would make much of a difference, but may.
question, with the amp inputs disconnected (both), do you have any noise?
Alan
Old 21st June 2012, 07:16 PM   #4525
Originally Posted by Bruno Putzeys View Post
..... though I think this might have been amplified by one particular member who's hell-bent on polarizing the whole discussion.....
Mention a name, or stop this vague insinuation... it's not "helping" the thread at all
Old 21st June 2012, 07:21 PM   #4526
I guess running the left input lead right below all the powerwiring and straight past the smps isnt helping much either
Old 21st June 2012, 07:43 PM   #4527
We have been asked by the moderators to drop this, let us do so.
Alan
Old 21st June 2012, 07:44 PM   #4528
Alan
Yes, no reason for BP to bring it up again...
Old 21st June 2012, 08:01 PM   #4529
serengetiplains's Avatar
With regards to supply current:
The Vsigs, as per heading 5 (titled "Recommended operating conditions and supply currents"), draw 40mA. The 10mA in the table above is not related to the supply current.
Thank you, Bruno. Great work on this amplifier. I'll post pictures and listening impressions when I have mine here and together.
Old 21st June 2012, 10:09 PM   #4530
Bruno didn't bring the issue up; he clarified in response to the poster who made the comment. If you have been following the thread you know who the member is, so there is no need to name names.
The point is that we are all here to help each other get the best out of the ncore. The ncore may not be for everybody. It's OK (even helpful) to let the members know where the ncore didn't meet your needs -- perhaps another member might even benefit from your experience. It's not OK to keep on bashing the product ad nauseum (sp?); better to just leave the forum.
Like everything else in life: keep it positive.
Michael
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
