hypex ncore - Page 423 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 30th May 2012, 06:58 AM   #4221
Julf is offline Julf  Europe
Originally Posted by Audioschipper View Post
That is right. It's an upgrade. Mine has it too so I asked Hypex. It is extra isolation.
Ah. So now we can have endless debates about the influence on sound quality
Old 30th May 2012, 07:59 AM   #4222
Ianmac is offline Ianmac  Scotland
Originally Posted by ajst2duk View Post
Brought them to life this morning - nice - yes I know the signal cable could be shortened but while I'm still experimenting, I've left the length on the cables just in case I change configuration. Unlikely though as they sound great and run cool.
I have built my two with a similar board layout.
You may find it an advantage to remove your rear panel and turn it round 180 deg so that your input is very close to the input socket on your amp and likewise your LS connections. With your LS connectors in the corner try and keep the LS cable away from the board and input cable. Hypex recommend twisting the LS cable. Extend or remake the mains cable and run it down the side of the amp and round the front of the SMPS well away from the input.
I eventually turned the SMPS round 180 to minimise the mains cable length and keep my ventilation slots clear of any possible obstruction but that meant making a new longer SMPS-NC400 interconnect from the cable supplied with the NC400. Took time and tested my soldering skills as the conectors are designed to be crimped.
The AMPS performance can only be described as SUPERB a credit to Bruno and the team at HYPEX
Have we now reached a point where Class D is better than a Class A gas guzzler ?
Ianmac
Old 30th May 2012, 08:19 AM   #4223
antbom is offline antbom  Italy
Here is my pair of NC400, built in Hifi2000 boxes (not so tight fit, height is 80mm):
Very ugly holes at the back panels, but I don't care too much.
Any critic/suggestion about wiring is welcome.
Antonio
Old 30th May 2012, 08:46 AM   #4224
StigErik's Avatar
Yeah right.
Plastic is not a natural material, thus it does not sound natural. We must use natural materials, like earwax, goatskin, cotton or linseed oil. According to some people, plastic insulation is evil you see.......
But according to me, audio (and "High-end" in particular) is a magnet to BS.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 30th May 2012, 09:13 AM   #4225
I guess we need more non-magnetic materials
Old 30th May 2012, 10:47 AM   #4226
robbbby is offline robbbby  Canada
Now I have to sell my original ncores so I get get the new ones with extra isolation, damnit.
Old 30th May 2012, 11:04 AM   #4227
I have one of each so I will probably loose my wits
Old 30th May 2012, 01:13 PM   #4228
It's not what I'd call an upgrade. Originally we counted on the two 3mm gaps (primary heat sink to core, core to secondary) to give us double insulation. Worked fine, until someone pointed out that if the primary heat sink was even slightly bent out of true the insulation distance would become compromised. These products are being put into the hands of people without formal electrical installation qualifications and this was one way to improve robustness.
There's a time for everything, and this is not it.
Old 30th May 2012, 01:36 PM   #4229
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
So do you suggest/recommend that we wrap insulation around the core?
Old 30th May 2012, 01:45 PM   #4230
I shouldn't bother unless you plan to drop the supply on the floor before it's mounted in a case.
Hypex problem, who can help Hansms Class D 9 18th August 2013 06:49 AM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
