hypex ncore - Page 362 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 11th April 2012, 03:42 PM   #3611
Hypex told me they do not adjust the shut down for the input an the fault must be there. I was promised I could send the PCB;s back for adjustment but I think we will leave them as they are.
Old 11th April 2012, 04:42 PM   #3612
You could run them at higher voltage as you are doing now, isn't it? This will give you a bit more power which you probably are missing now.
Old 11th April 2012, 04:42 PM   #3613
Julf is offline Julf  Europe
Well, as the input stage only draws 40 mA, it would be really easy to use a couple of zener diodes to stabilize that voltage - allowing you to go back to full power on the main supply.
Old 11th April 2012, 04:44 PM   #3614
Originally Posted by Mark.Clappers View Post
Did you have a look with a microscoop? I use a stereo scoop with 10X magnification, with this I am able to see the tiny solder briges that are sometimes left behind when removing smd components, with the naked eye these are very hard to spot.
No, didn't use a microscope, but a 8x magnifying glass - pretty sure there are no solder bridges.
Old 11th April 2012, 04:45 PM   #3615
I use a 2mm flat tip with a blob of solder. Works like a charm!
That's how I do it too.
Old 11th April 2012, 05:34 PM   #3616
Yes a bit, no big difference tough ! 20 w or something near that.
Old 11th April 2012, 05:36 PM   #3617
Mark.Clappers's Avatar
Then the only thing I can think of is the "reflow" methode (with a hot air desoldering gun and some flux)..
Music is art - Audio is psychoacoustics & engineering
Old 11th April 2012, 05:37 PM   #3618
Zener diodes are noisy !
Old 11th April 2012, 07:05 PM   #3619
Something a filter capacitor can't fix?
Old 11th April 2012, 08:04 PM   #3620
I don't get what's happening (= I forgot ), is the danger that he would exceed the voltage limits for his input stage, so he has dropped his rail voltage to provide it directly? Zeners with a cap bypass would surely work, but I understand Erlend wanting to find the cleanest possible source. He could use a IC regulator or precision voltage source...if there were room for that...But if the voltage simply feeds regulators like the HxRs, which have an incredibly high PSRR, your zener/cap suggestion would be as clean as anybody could want.
Also wondering about your resistor woes...obviously you measured for shorts and opens both within and near the resistor afterwards. I've had stray fibers of copper do a job on a circuit, then disappear with a good shake or compressed air. Do you think a semiconductor was blown from the incident? When I see a total collapse with no visible damage, that's what I suspect next.
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
