| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#3581 | ||
#3582 | |
![]() No Hum at all even at 108 DB system with NC. In my room and with my speakers I need more power. |
#3583 |
Maybe bridging two ncore´s per channel could do the trick for you.
They can deliver 24 A´s so unless your speakers are of very low impedance, bridging two ncores should provide significantly more head room... |
#3584 |
You need more power than the NC400 ?
I guess you must have some very low sensitivity speakers, or you want to play loud as h***. I rarely exceed 10W even on my 88 dB ribbons.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#3585 |
My speakers is able to make you jump in the sofa with the right amp. Nc did not do that job ( another pre maybe ). They are 88 DB to.
You have to hear my system to understand what I am talking about. Basreflex are seldom able to kick ***. Ups now users are going to kick mine !
#3586 | |
Well I just ordered some other moduls. If it where possible to buy the NC 1200 I would have done that. My Coldamp can not follow the NC in midrange / treble. |
#3587 |
So the NC is the better amp compared to your modified Coldamp, except for "big dynamic jumps" where a lot of power is needed? You are using 900VA transformer per channel at the moment isn't it? I can't immagine you can improve with even more power of the transformer.... Doesn't the big capacity make your amp "slower"???
You don't feed it with the same voltage as the SMPS600 provides, is it? You give away some power because of that. Last edited by Mark Verhoeven; 10th April 2012 at 08:28 PM. |
#3588 | |
#3589 |
Hypex advises to use 4700 uF per channel.
#3590 |
| Hypex problem, who can help | Hansms | Class D | 8 | 10th March 2011 08:18 PM |
| Hypex | steveww | Class D | 14 | 18th November 2010 01:44 PM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
