hypex ncore - Page 303 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th March 2012, 12:58 PM   #3021
dan1502 is offline dan1502  United Kingdom
Originally Posted by Immelman View Post
OK, thank you. I'll take a look. My downfall is I'm new to all this. I've built some crossovers but that's it, and I'm not an electronics major. So that can make me seem about 80 IQ to you guys . The pictures of the completed amp look simple enough, but shunt regulate this and should I ground to earth at the circumference X...
You guys make it sound scary.
I haven't looked at any of the material yet but I'm hoping to just order the parts I need, chassis, solder some parts, and call it good. You guys make it sound like putting together the amp is some kind of delicate surgury.
I'm completely new to this too. All I have done to date is make some speaker cables and put some mains filters in boxes but I am reasonably good at DIY in general. The hardest part is finding enclosures you are happy with and working out the layout, wiring, switching you want, whether or not you want an LED etc and sourcing the components though there are pretty much ready made options available as I understand it. Other than that there is a small amount of soldering (and/or crimping) and using the optimal wiring methods.
I need to re-read all the Hypex techncial guidance again and this thread as my main concern is getting the earthing, mains and signal wiring just right. All the information is available but I will probably make a final post to check my understanding is correct. I will probably come accross as being dumb when I do but I will just want to be absolutely sure I've understood everything correctly and my optimal wiring conclusions are right before connecting everything up.
(short version - go for it )
Old 20th March 2012, 01:09 PM   #3022
yetis is offline yetis  United States
I need to re-read all the Hypex technical guidance again and this thread as my main concern is getting the earthing, mains and signal wiring just right. All the information is available but I will probably make a final post to check my understanding is correct. I will probably come across as being dumb when I do but I will just want to be absolutely sure I've understood everything correctly and my optimal wiring conclusions are right before connecting everything up.
And we emerge! I too fall into this category and will agree that getting the case and all the cut outs sorted out has been the hardest.
Old 20th March 2012, 01:10 PM   #3023
Julf is offline Julf  Europe
Hey - it isn't a real DIY project unless you let out some of the magic smoke the first time you try turning it on!
Old 20th March 2012, 01:22 PM   #3024
zhai is offline zhai  Denmark
How about loud bangs coming out of the speakers after you power it up, does that count? =D
That's exactly what happened to me when I first powered on my ncore with a buffalo feeding it. I panicked and sent the modules for RMA because I saw some sparks after first powering the smps modules without load and then seeing sparks when I connected the modules afterwards.
Turns out the modules were undamaged, so it's still a mystery what caused the loud bangs.
So now I have everything assembled again, and turning on the ncore with speakers connected but no source looks fine, and no bangs. Now I'm just scared connecting the buffalo dac to the ncore, because I'm guessing there's a high likelihood that the buffalo was causing the noise.
I'm using the legato 3.1 from twisted pear as the actual balanced output. The s/e part works perfectly.
So is there a way to check that the balanced output is behaving properly? Or do I have to adjust something before connecting the legato balanced to the ncore?
Old 20th March 2012, 01:30 PM   #3025
Send a message via Yahoo to mr_push_pull
in case anyone's wondering why Bruno seemed a bit busy lately...
http://www.mola-mola.nl/epk_files/Mo...%20en%20nl.pdf
we all love a good ol' stereotype until it's against us
Old 20th March 2012, 01:35 PM   #3026
Sure! Congratulations - you have a real DIY project
Sounds like you have some DC on the output of the Buffalo. I suggest you try with a couple of capacitors between the Buffalo and the nc400 - and turn on the Buffalo before you turn on the nc400.
Old 20th March 2012, 03:29 PM   #3027
Mola-mola is a fun name. Will be interesting to compare them to my Manley mahi-mahis.
Old 20th March 2012, 03:36 PM   #3028
Omholt is offline Omholt  Norway
Cool.
Will be interesting how they price their products. Hopefully not like many other high-end brands.
Would be great if Hypex also could provide separate preamp and DAC for the DIY market.
Old 20th March 2012, 04:46 PM   #3029
what I find funny is that they chose a curvy top similar to the Theta one.
I'm not expecting those to be cheap.
Old 20th March 2012, 04:58 PM   #3030
Think they would sell me one of those cases for my Ncore monoblocks?
Hypex problem, who can help Hansms Class D 9 18th August 2013 06:49 AM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
